PN problem ID 55652
mapletree
PN problem ID 55652
Hi,  I have just had the aforementioned problem ID mentioned as being related to a ticket I have raised.  However I cannot find any information on it.  Can anyone assist?  Thanks.
Fixes: 21
Re: PN problem ID 55652
If it were a priority problem you should be able to find it here - http://portal.plus.net/support/service/problems/index.php?supporta=priorityproblems and it's not closed or downgraded. PN do not seem to be able to provide any links to these lower priority problems, always been one of my gripes.
mapletree
I should have stated that I had already checked the priority and downgraded problems.  I would have thought this problem (all mail from a particular source silently dropped) should be a priority!
Hi mapletree,
I can confirm that this problem is in hand with our networks team and is currently being worked on.  I'll get you an update soon.
Fixes: 21
Ah, now you've explained what it's about, have you checked the Member Centre, Manage My Mail (MMM), Spam tab here .
Check that 'Discard obvious Spam'  is OFF. See if that makes any difference - if not, at risk of getting a bucket load of spam for a short while, turn spam protection off altogether, see if that makes a difference. (Don't forget to note the delay before some changes take effect).
mapletree
I've already tried all the different permutations of the spam filter.  Only turning filtering off completely makes the difference.
It seems to be taking a very long time to sort out the fault.  I raised a ticket two weeks ago and it's not only affecting me.
James
Hi Mapletree,
Looking at the notes on the actual problem itself, it does seem to be rather complicated and I can see that a lot of work has been done already to try and fix the problem.
I'll try andget an update later on to see how things are progressing.
mapletree
My ticket appeared to be forgotten/ignored twice and then things still keep going very quiet so I was uncertain whether anything was happening.  Thanks for the reassurance.
mapletree
It's gone very quiet again.  Is there any progressHuhHuh
Fixes: 77
Quote from: mapletree
The problem you've quoted is primarily to investigate failed mailing list creations. Is this what you're having problems with because the above quote suggests otherwise?
mapletree
Bob,
PN problem ID 55652 was quoted to me as being related to my ticket.  I have no idea about mailing list creations.  The actual problem is described in ticket 28058918 -- all emails from a certain source (an email alias) do not reach me (unless I turn off spam filtering completely).
So I am guessing that 55652 has nothing to do with my issue?
Fixes: 77
It doesn't look like it to me (although the problem is very complex so I'd need to seek clarification). Your problem on the other hand has just baffled the living daylights out of me! I'm going to do a bit more digging but in the mean time I'd be interested to know what happens if you try sending to the list using Webmail?
It might be a red herring but your problem seems to have started when we put the IronPorts in front of the Brightview (Madasafish) email platform.
mapletree
I got the "550 - relay not permitted" bounce message if I tried to send using webmail with spam filtering on.  With filtering completely off the message comes through OK.
Others have reported not receiving any kind of bounce or error message.  I am not the only person who is experiencing this exact same problem BTW.
I can try turning the filters back on if that helps.
