PN Portal registration problem
mcgurka
Guys, a problem to pass to web / dev would be that when you register for a bussiness account, and use DD as payment you are asked for the account details, as follows;
First name: [type here]
Last name / Business Name *: [type here]
which is fair enough. So business uses fill in the second half only? Right?
The site wont allow you to leave the first name box blank, and there is no asterisk, so you should be able to.
I've had a few DD's bounced by the back because of this issue.
James
Re: PN Portal registration problem
Yep, I've seen this a few times.
Will get it raised now.
James
I've just spoken to QA and this apparently already recognised as a problem.
They're going to try and see where it currently is and get a fix sorted as soon as possible.
mcgurka
OK, thanks James!
