PN Line Profile holding me back?
davidfriedlande
can my profile be raised a little higher based on the below??  short up time on router was me restarting due to a config change, previously up for 3 days+
FAQ
Results Image not loaded
1. Best Effort Test:  -provides background information.
Download  Speed
7.65 Mbps
0 Mbps 21 Mbps
Max Achievable Speed
Download speedachieved during the test was - 7.65 Mbps
For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
IP Profile for your line is - 8.3 Mbps
2. Upstream Test:  -provides background information.
Upload Speed
0.86 Mbps
0 Mbps 0.83 Mbps
Upload speed achieved during the test was - 0.86Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.83 Mbps
Estimated line speed:
4Mb (This may vary between 3Mb and 7Mb) - Checked on 2014-03-07 17:22:01
Current line speed:
8 Mb
Host Name home.gateway
System Up-Time 3 Hour(s) 29 min(s)
Current Time Fri Mar 21 09:00:33 2014
Hardware Version Annex A
Software Version 1.06h
MAC Address 00:04:ed:da:33:25
LAN IPv6 Address fe80::204:edff:fe24:dce/64
Physical Port Status
Ethernet
EWAN Down
ADSL Up 1063 / 9411 kbps
Wireless
Re: PN Line Profile holding me back?
Your speed is matched Plusnet's end (8Mb/s) against your IP Profile (8.2Mb/s) so there is nothing wrong there - can you post your estimated speeds from here http://www.dslchecker.bt.com/ ?
Fixes: 58
The Plusnet profile should be 8.3 to match the IP profile as it goes in 0.1Mb/s steps
Plusnet Staff
Plusnet Staff
Fixes: 5
Your sync rate is currently standing at 9411 which would give you a Plusnet Profile of 8.3 as Oldjim has stated below.
I've updated this for you.
Chris Pettitt
Cloud Environments Engineer
davidfriedlande
Thanks guys, its the little differences that count!
