PN IP profile check/change?
- PN IP profile check/change?
- « Previous
- Next »
Re: PN IP profile check/change?
01-08-2015 6:05 PM
Still lovely quiet line and very fast broadband:
Download speed achieved during the test was - 6.29 Mbps
For your connection, the acceptable range of speeds is 0.6 Mbps-7.15 Mbps.
Additional Information:
Your DSL Connection Rate :6.98 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
IP Profile for your line is - 6 Mbps
Happy if this holds.
Message 121 of 125
(467 Views)
01-08-2015 7:35 PM
Hmm. Interesting. I'd guess the fault might be fixed, I do hope so. Have you been tweaking?
It will be interesting to see SNRM graphs, especially overnight for that speed. As mentioned previously, it'll be a bit of a trade-off between errors and throughput speed, more so at night if the SNRM doesn't go too low for the connection to drop. Good Luck with it
Message 122 of 125
(467 Views)
01-10-2015 10:03 PM
Thought I'd post here first before raising a fault again.
Line has been perfect since the fault was fixed by BT back in early August, 7M sync, very stable.
I've been away for a few days and the line is synced at just 288kbpsm with a SNR of 29dB. I've tried rebooting the modem, there is no obvious noise on the line when 17070#2
Anything else to check?
Adam
Adam
Message 123 of 125
(467 Views)
01-10-2015 10:06 PM
That is odd - very like the problem reported here http://community.plus.net/forum/index.php/topic,144413.0.html
Message 124 of 125
(467 Views)
02-10-2015 9:44 AM
Does look similar! Still bad this morning.
I'll get on to phone support.
A
A
Message 125 of 125
(467 Views)
- « Previous
- Next »
