PN IP profile check/change?
gingerbloke
BTW speedchecker shows sync of 4.5M, IP profile of 3.5M but my line has been slow for days.
Can someone check the PN IP profile matches the BTW one pls?
Adam
Download speed achieved during the test was - 1.53 Mbps
For your connection, the acceptable range of speeds is 0.6 Mbps-7.15 Mbps.
Additional Information:
Your DSL Connection Rate :4.51 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
IP Profile for your line is - 3.5 Mbps
124 REPLIES 124
Jaggies
Re: PN IP profile check/change?
You can check yourself, here - https://portal.plus.net/my.html?action=data_transfer_speed - once you've logged in.
gingerbloke
Thanks for that, didn't know you could check it.
Reckons it's 1.5M (so out of step with BTW IP profile).
How do I get it reset, or is it a case of 'hurry and up wait' Smiley
Generally, what is the point of IP profiles (a BT one and a PN one), surely any intelligent queuing system could just be using recent sync speed data? It's very frustrating to have a modem sync'd at 4.5M and be getting 1.5M.
plusnettony
Plusnet Staff
Plusnet Staff
Fixes: 18
I've manually changed this for you. Drop your broadband connection and re-connect to see the new speeds.
Post back if you have any problems.
 Tony T
Oldjim
Resting Legend
Fixes: 63
Try live chat or phone in as there is apparently no delay at present
http://portal.plus.net/supportpages.html?a=212
The reason for the Plusnet profile - brief explanation - is that if the data arriving down your line comes faster than the line can handle the BT Profile drops random packages whereas the Plusnet one is more intelligent and drops non urgent packets preferentially so things which are time sensitive aren't impacted by downloads as an example
Edit - I see it has been picked up here
gingerbloke
That worked, now download is actually faster than the IP profile ( ???)
Download speedachieved during the test was - 3.75 Mbps
Your DSL Connection Rate :4.26 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
Fixes: 160
Sight of your router stats would confirm that your line is actually running optimally.
gingerbloke
Spoke to soon Sad
Download speed achieved during the test was - 2.04 Mbps
For your connection, the acceptable range of speeds is 0.4 Mbps-2 Mbps.
Your DSL Connection Rate :4.61 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
IP Profile for your line is - 2 Mbps
MatthewWheeler
Fixes: 479
That might have something to do with the below
The burst of disconnections between 10am and 11am will have most likely caused your profile to drop again.
We need to get the drops sorted first and foremost. Was there any noise on the line or bad weather at that time this morning?
 Matthew Wheeler
Fixes: 160
Quote from: Townman
gingerbloke
It's a recurring problem on my line - there's crackling sometimes, but not often enough that a BT engineer will see it when he visits. The line will disconnect and sync lower, eventually ending up with a crippled IP profile even when the line has gone silent again and sync is back up. I wait 3 days after the noisy line and we're running 5M+ again.
It also drops ADSL occasionally when the phone rings - but (again) not a repeatable fault.
I'll raise a call again and hope the line is noisy when he turns up. Last time this happened it took 9 visits from BT before they found a worn out cable in a tree nearby.
Router has been connected for 5 hours or so, at 4608 with a SNR of 8.5 - when the line runs well I get a sync of 5.0 - 5.5Mbps and actual download speed of around 450Kbytes/sec - good enough for iPlayer HD, etc
Fixes: 160
In that case you need to report an INTEMITTANT voice / noise fault, particularly the disconnects on inbound calls.  Until that is fixed, looking at the BB performance is completely futile.
If PN provide the phone service, use the phone faults link below.
gingerbloke
It's been great since I last posted but it's crawling this morning.
BTW shows :
Download speed achieved during the test was - 0.1 Mbps
For your connection, the acceptable range of speeds is 0.05 Mbps-0.25 Mbps.
Your DSL Connection Rate :4.42 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
IP Profile for your line is - 0.14 Mbps
Oddly enough, the line is very quiet but it was very crackly over the weekend. I'll raise a line fault and see what happens.
A
plusnettony
Plusnet Staff
Plusnet Staff
Fixes: 18
I've not found a problem on the line, but as you say, it's intermittent.
You're syncing at 4.4Mbit currently.
The delta report to us, at 7.21 this morning was 200k, hence the current speeds. We just need these to lift and you'll be OK (hopefully)
 Tony T
gingerbloke
Thanks Tony,
I've raised a line fault, #103927416
The phone line was perfect for several hours yesterday afternoon, then went noisy for about an hour (causing several reboots) - I'm running a routerstats on it to record.
I've made calls today that were perfectly clear, and two that were very poor.
