PLUSNET PROFILE visa vis BT PROFILE
VileReynard
Fixes: 20
Please could you push my PN profile up to match my BT profile?
Download speedachieved during the test was - 4666 Kbps
Additional Information:
Your DSL Connection Rate :7131 Kbps(DOWN-STREAM), 1099 Kbps(UP-STREAM)
IP Profile for your line is - 6000 Kbps
PN have my profile at 5.5Mbps Cry
Isn't 21CN great!
6 REPLIES 6
James
Re: PLUSNET PROFILE visa vis BT PROFILE
Don't know what you mean? Wink
VileReynard
Fixes: 20
Thanks James Smiley Smiley
chrisyoung
how long does it take pn to update my profile.
my bt profile is at 17000 but my pn profile is at 5500.
is there any chance of getting this pushed on?
scootie
@chirsyoung. the PN profile should follow suit with changes in your BT profile within 12 hours.  if you have gone aday with out a change then it most likely needs a poke
James
Chris,
Looks like yours has changed automatically.
chrisyoung
yeah it changed just after i posted that message
