PAYG to BBYW2?
- PAYG to BBYW2?
PAYG to BBYW2?
02-05-2008 9:35 AM
Anyway, can anyone think of a reason why I shouldn't just 'upgrade' to BBYW2 with a comfortable 15Gb limit at the same price?
I VPN to work so BBYW1 is out. I don't use VOIP either.
Robin
Re: PAYG to BBYW2?
02-05-2008 9:37 AM
Unless you're looking at using P2P/Usenet, then you shouldn't really notice any changes.
Re: PAYG to BBYW2?
02-05-2008 9:38 AM
B.
Re: PAYG to BBYW2?
02-05-2008 9:45 AM
Re: PAYG to BBYW2?
02-05-2008 10:18 AM
Bit worried now......
Re: PAYG to BBYW2?
02-05-2008 10:27 AM
Phil
Re: PAYG to BBYW2?
02-05-2008 11:04 AM
Quote from: the I manage a couple of webistes for 2 local sports clubs - is that where I willl feel the difference with the ftp speed (uploading content?) it looks like a massive difference.
Yes, that's where you'll feel the difference - I'm in a similar situation to you, and FTP is noticeably slower than with my previous provider. That said however, it works, and general web & email (Which is the majority of my usage) is excellent and it's cheaper than I was paying so overall I'm happy.
Re: PAYG to BBYW2?
02-05-2008 11:27 AM
In response to this post
James responded with
Quote Indeed - the FTP restrictions are the only thing I dislike about BBYW Option 2. I download very small files regularly every evening, and they take an age to come down compared to my old provider
Any change of getting these bumped up a bit? Maybe to 512k?
from here
Quote On my list for things to chase today
Re: PAYG to BBYW2?
02-05-2008 12:16 PM
Re: PAYG to BBYW2?
02-05-2008 12:32 PM
I'll go do the upgrade now.
Re: PAYG to BBYW2?
05-05-2008 8:13 PM
I very occ go over my download limit of 2Gb. I dont use P2P/Usenet, or FTP either. All me and the wife do is surf, use E-mail, use You Tube occasionally ( usually between 19:00 and 22:00, when the youngster has retired for the evening), and occ download stuff from places like filehippo, etc. Reason I liked PAYG, was the lack of traffic shaping. Would moving to BBYW 2 be detrementil to me at all, with the download limits from download sites. Have a very stable 4.5-5.0 connection. For instance just downloaded XP-SP3 full installer ( over300Meg 19:30), this was at a stable download rate of 525kbps ish. ( this was from microsofts servers however!!) Would this change with BBYW 2? or should I just stay with PAYG.
Re: PAYG to BBYW2?
05-05-2008 10:18 PM
I believe that the Microsoft servers are classed as download servers so will be significantly slower on BBYW Option 1 or 2 as the expected rate is 1,000kbps
Re: PAYG to BBYW2?
05-05-2008 10:50 PM
Peace be with you Penfold, say hello to DM for me.
Re: PAYG to BBYW2?
06-05-2008 9:19 AM
God DM says hi
Re: PAYG to BBYW2?
06-05-2008 10:50 AM
