P2P Throttled on Fibre?
Gryzor
Seems I am getting slower speeds on fibre at 25Mb than I was on my 2.5Mb.  What gives?
Fixes: 154
Re: P2P Throttled on Fibre?
which package are you on?
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
Fixes: 62
That is interesting
Comparing Extra and Extra Fibre
Extra is nominally faster outside 6pm to 10pm for P2P
houlton23
Quote from: Oldjim
Strange decision by PN there..
@Gryzor You can view all rate limits here.
Estragon
There's a few more oddities as well Oldjim, once you get your head round the massively different time spells. Extra Fibre has several strong throttles that Extra doesn't.
I have a vague recollection that the tighter reins in the busiest hours were justified because of the vastly greater speeds that were then available (to fibre) in the non-peak hours. It's a vague rec ollection, so I might be wrong...
Plusnet Customer
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
