P2P Connections on TG582n
- P2P Connections on TG582n
10-02-2013 12:02 AM
I just wondered what settings people were using on their p2p clients for the TG582n?
Seems even on the lowest connections after a while, the router/modem seems unable to process any DNS requests from its configured servers.
(If I have alternate DNS on the PC it works fine).
Message 1 of 8
(2,908 Views)
7 REPLIES 7
Re: P2P Connections on TG582n
11-02-2013 12:24 PM
Is this the Fibre version or ADSL version of the 582n and what's the Firmware version?
Message 2 of 8
(866 Views)
11-02-2013 1:19 PM
Message 3 of 8
(866 Views)
12-02-2013 3:04 AM
Every router or modem has a limit to how many concurrent connections it can handle and I believe the results are often posted in routers reviews.
I have the standard, non fiber version and even with just one torrent or game updating via p2p I either get a loss of DNS(I can download still, router stays up but can't visit websites. This goes away on its own but comes back again with continuous downloading via p2p. if downloading stops the device recovers to normal faster and the problem doesn't repeat.
Or, more rarely I get a reboot.
adie:quote
adie:quote
Message 4 of 8
(866 Views)
12-02-2013 8:08 AM
are you leaving your upstream uncapped when using p2p, if so that could be causing your issue.
Message 5 of 8
(866 Views)
12-02-2013 12:15 PM
Quote from: Dodgexander Every router or modem has a limit to how many concurrent connections it can handle and I believe the results are often posted in routers reviews.
I'm sure I read something recently specifically in relation to this and the 582n, and I thought it was somewhere on these forums, but I can't find it at the moment
Message 6 of 8
(866 Views)
12-02-2013 1:50 PM
Quote from: dvorak are you leaving your upstream uncapped when using p2p, if so that could be causing your issue.
Yes, my upload is limited.
Quote from: Anotherone
Thanks, would be great to find something like this: http://www.smallnetbuilder.com/lanwan/router-charts/bar/77-max-simul-conn, concurrent connections is a major problem for a lot of routers and I have encountered a similar problem before. I am scared the amount this Technicolor router supports is very little.
Message 7 of 8
(866 Views)
12-02-2013 2:03 PM
According to some Technicolor release notes for "Main Track Slotted Release R8.4.3 Maintenance 2", the maximum number of simultaneous connections was increased from 2000 to 4096, although that PDF doesn't specifically mention the TG582n, only various better models.
Message 8 of 8
(866 Views)
