Own Router - PlusNet Password
daNutz
Im just preparing for the move from EE to PlusNet at the end of the month and im looking at the connection documentation and notince it states
Broadband username or login name yourusername
@plusdsl.net
Connection type or encapsulation PPPoE Always On
Password The password you use to log in to the My Account
Can someone confirm this is correct and that i use my password that i use to login into my PlusNet Account? as im confused by the my account page where it says "Password: The one you chose when ordering." as i don't know what this is as i had to reset my password.
If using my PlusNet Account password is correct, then what is the point of the below option?
I simply dont want to be stuck trying to sort out access when my EE service is switched over.
TIA!
2 REPLIES 2
Fixes: 244
Re: Own Router - PlusNet Password
Is is the same password you use to login to the user portal.
Fixes: 579
  • Can someone confirm this is correct and that i use my password that i use to login into my PlusNet Account?
yes
