Overnight usage question
- Overnight usage question
14-01-2013 11:38 PM
If you start a download at say 11pm that will take 2 hours,
would the second hour be correctly recorded as overnight usage.
Message 1 of 4
(826 Views)
3 REPLIES 3
Re: Overnight usage question
14-01-2013 11:44 PM
I am going with yes.
I would imagine it's quite easy for the systems to know what time it is and stop/start counting data.
Message 2 of 4
(459 Views)
15-01-2013 12:19 AM
They should split this correctly into peak and overnight. BT supply usage information in blocks and any block extending over midnight (or 8am) is completely disregarded to avoid usage being apportioned incorrectly.
David
Message 3 of 4
(459 Views)
15-01-2013 10:59 PM
Thanks for your help well give it a try tonight
Mike
Mike
Message 4 of 4
(459 Views)
