Outages
- Outages
Outages
19-12-2020 1:46 PM
Been off for 16 hours, called support, 1 hr 22 mins queue to be told there's outages in area. Yet the plusnet status pages shows no outages! Then the standard message that its BTs fault and they are working on it
Message 1 of 2
(231 Views)
1 REPLY 1
Re: Outages
19-12-2020 2:04 PM
@Kwr The Plusnet status page is only updated for major outages, not local ones. That 'standard message' is all Plusnet can give you - they are not responsible forthe BT network, nor can they influence a resolution.
Message 2 of 2
(225 Views)
