Ordered and less than an hour got probs!!!
- Ordered and less than an hour got probs!!!
Re: Ordered and less than an hour got probs!!!
04-03-2009 5:43 PM
04-03-2009 6:11 PM
It may also be possible that you are back in a "learning period" of 10 days where the DSLAM automatically tunes your connection for best speed. It is best to leave your Router switched on during this period and re-start it every 2-3 days around mid-day to allow it to re-sync.
What is your current SNR Margin?
04-03-2009 6:19 PM
04-03-2009 6:34 PM
Fron the Sidebar select Broadband Connection and from the dropdown, DSL Connection
Look at the toolbar at the RHS and click on Details.
If not a Thomson, what is it?
04-03-2009 8:18 PM
04-03-2009 8:29 PM
You will need to follow your nose from there.
04-03-2009 8:40 PM
04-03-2009 9:26 PM
Were the speeds you posted earlier from a Speedtester?
04-03-2009 10:57 PM
Downstream Upstream
Data rate (Kbps)
7424 448
Noise margin (dB)
5.8 25.0
Output power (dBm)
19.7 11.9
Attenuation (dB)
36.0 22.0
Hope this means more to you than me! The speeds i posted were from Plusnet's speedtester
04-03-2009 11:54 PM
Your stats look good and very similar to mine but I am on the PRO Profile so would expect a better data rate than you are seeing.
05-03-2009 8:01 AM
05-03-2009 10:55 AM
When you say slow, how slow do you mean?
It's classified as a download site (Rapidshare that is), and as such we rate limit the speeds at some points of the day.
05-03-2009 1:05 PM
05-03-2009 1:08 PM
05-03-2009 1:12 PM
