turn on suggestions
Order stuck on checking line for over 2 and a half weeks
- Order stuck on checking line for over 2 and a half...
15-07-2014 8:11 AM
My broadband order has been stuck at the Checking your Line stage for 2.5weeks, is this normal? When I ordered it said it'd be complete in 7-10 working days.
Re: Order stuck on checking line for over 2 and a half weeks
15-07-2014 9:53 AM
Silly question, but have you supplied your MAC to PlusNet (if this is a migration)?
If you have, probably best to phone to find out what is going on. And check for tickets on your account, there may be some information there.
15-07-2014 9:56 AM
Hi Paul,
Thank you for your time on the phone, as discussed please let us know when you get your router and we'll activate your account so you can connect.
15-07-2014 2:21 PM
Hey Again,
Thanks for the call Chris, you were very helpful, I received notification that the modem/router has now been despatched and I will let you know when it's arrived so we can get switched on finally
Thanks for the suggestion HP, but I had supplied the MAC with the order
Cheers, Paul
Cheers, Paul
15-07-2014 2:55 PM
I just recall others having been stuck because of that and the system being rather "uninformative" to say the least.
Quote from: paulbarnard6 Thanks for the suggestion HP, but I had supplied the MAC with the order
What was the problem, if you know? Might be of help to others in future.
17-07-2014 8:21 AM
Hi guys,
HP, I don't know what the problem was, but for some reason it was just the ordering process getting stuck, Chris gave it a nudge
Chris, the router has arrived now, so if you could give the system the final nudge and activate my broadband as discussed and confirm that would be excellent and I can finally get setup and sorted today
Thanks, Russ
Thanks, Russ
17-07-2014 9:27 AM
Hi Russ,
That's sorted for you now, see if you can connect.
