Order status query
- Order status query
Order status query
22-05-2011 5:07 PM
Hello all
Placed an order a few days ago to migrate to PN Pro.
Logged in to check order status this weekend and noticed that an exclamation mark icon is against checking your line along with the message "We've found a potential problem on your telephone line. We'll look into this and will be in contact with you shortly."
Had a look at help assistant and the last entry there is:
Provisioning of your ADSL Account Information
Install diary status changed from Application Submitted to Application Rejected
(via ADSL2+ Order System Interface)
Is this bad news?
Thanks in advance
Is this bad news?
Thanks in advance
Has anyone seen my signature, it's gone missing.
Message 1 of 9
(4,883 Views)
8 REPLIES 8
Re: Order status query
22-05-2011 7:57 PM
Welcome to the forum Vultura.
One of the Digital Care team will be able to answer your question tomorrow.
Message 2 of 9
(652 Views)
23-05-2011 12:44 PM
Thanks for the welcome Strat.
I do hope they can answer this query and that its normal(ish).
jim:quote
jim:quote
Message 3 of 9
(652 Views)
23-05-2011 6:09 PM
Just a quick update and it might help someone else in future.
Have just called tech support, seems the MAC code I typed in was missing a digit, silly me.
Hopefully it will all go smoothly now.
Message 4 of 9
(652 Views)
23-05-2011 6:11 PM
Here's hoping so
Message 5 of 9
(652 Views)
23-05-2011 7:02 PM
Don't hold your breath!
Message 6 of 9
(652 Views)
01-06-2011 1:41 PM
Hopefully it will be activated after 12pm tomorrow.
@Devonian - is that a comment on other providers/migration issues or plusnet?
Message 7 of 9
(652 Views)
01-06-2011 5:12 PM
Hi vultura,
Just checked your account and the order had completed, so I've activated it for you. You should be good to connect whenever you're ready
Hope that helps,
Hope that helps,
Message 8 of 9
(652 Views)
01-06-2011 7:17 PM
Thanks Matt
Have only just seen your message. A little puzzled when I got home to find my router was connecting/disconnecting. Had a look in its admin panel to see its showtime status as connected and at higher speeds than it was before. Good job I had the new settings copied down onto my netbook. Quick change and I'm up and running
Message 9 of 9
(652 Views)
