Orange light on router
John2773
Came home from work yesterday evening and I noticed that the orange light was flashing on my router. Carried out the on line help to fix but no joy.
Does anyone have any other help advice?
2 REPLIES 2
Gel
Champion
Fixes: 29
Re: Orange light on router
MatthewWheeler
Fixes: 503
Sorry to hear this.
It looks like your router is stuck in it's automated setup.
To fix this you can reset the router using the pinhole on the back or follow the steps below
1) Open a browser
2) Enter 192.168.1.254 into the address bar
3) On the router's home screen, select 'Settings'
4) Enter the password. This is the 'Admin Password for Hub Manager' on the removable card on the rear of the router (it can also be found on the base of the router)Within the 'Settings' menu, select the 'Broadband' tab or 'Enter your broadband username and password'
5) On the following page, you must enter the broadband username and password (There is a 'show characters option on this page if you are struggling with entering the password)
6) Click the 'Connect' button. The power light should turn blue to indicate that there is an internet connection.
After the 3rd of November I will have a limited presence here as I have moved to a new role
 Matthew Wheeler
