Orange flashing hub 2
Free_My_Soul
Hello,
Not a newbie to PlusNet as I've had broadband with them before but am a newbie to their fibre broadband.
On my hub 2 set up, all cables plugged in correctly but the router is showing an orange flashing light.
I'm at a loss how to fix this as I'm not that savvy with different kind of set ups.
Any suggestions please?
Thank you.
22 REPLIES 22
Fixes: 334
Re: Orange flashing hub 2
@Free_My_Soul Welcome to the forum.
I this your first attempt to connect, or have you previously had a connection and lost it?  I'm wondering if you are not yet connected.
Free_My_Soul
Thank you very much 😊
I activated it yesterday so first time to connect.
Fixes: 334
OK - so have you had notification from Plusnet that your account is live?
Free_My_Soul
I had an email on Tuesday saying my broadband is now up and running.
Fixes: 334
OK - try rebooting the Hub. Push a paper clip or similar into the reset hole on the rear and release once the light goes green, then wait for it to settle.
Free_My_Soul
Did the reboot but nope, still orange flashing light
Fixes: 334
Last thought, before I suggest calling Plusnet - what username is showing on the Hub?
Free_My_Soul
I have no idea, sorry
Fixes: 334
Log into your Hub, navigate to the page below - it will show on there.
Free_My_Soul
Setup@plusdsl.net
Fixes: 334
Try changing it to 'yourusername@plusdsl.net' and enter your PN password, where 'yourusername' is the one you chose when setting up the account.
Free_My_Soul
Is it my password or PlusNet's?
Fixes: 334
It is the one associated with your account, which, again, you will have chosen when setting up the account.
Fixes: 526
@jab1 it wont make any difference I'm afraid, if there's no DSL sync!, as indicated by the flashing orange light.
@Free_My_Soul how is your Hub connected to the phone line ?
Are you connected to the Master socket ?
Do you have a dual DSL / Phone master socket ? or are you using a DSL filter ?
