Opps Talked to soon Asus DSL-N55u Problem
OshB5
Hi All
It looks Like I have a problem with this Modem/Router. I just noticed that it had gone down. So I checked back in the history and it looks like its been going down quite a lot But as its been coming back up I have not noticed it till just. Here is a dump of todays Sys Log
Could it be that the setting of PPPoE that I have still got set is causing this to happen?
Apr 25 00:17:56 smbd[1322]:  reply_sesssetup_and_X:  Rejecting attempt at SPNEGO session setup when it was not negoitiated.
Apr 25 00:17:56 smbd[1323]: [2014/04/25 00:17:56, 0] smbd/sesssetup.c:reply_sesssetup_and_X(1265)
Apr 25 00:17:56 smbd[1323]:  reply_sesssetup_and_X:  Rejecting attempt at SPNEGO session setup when it was not negoitiated.
Apr 25 02:54:37 WAN Connection: Ethernet link down.
Apr 25 02:54:37 stop_nat_rules: apply the redirect_rules!
Apr 25 02:55:08 pppd[326]: Serial link appears to be disconnected.
Apr 25 02:55:14 pppd[326]: Connection terminated.
Apr 25 02:55:14 pppd[326]: Modem hangup
Apr 25 02:55:15 miniupnpd[1080]: ioctl(s, SIOCGIFADDR, ...): No such device
Apr 25 02:55:18 miniupnpd[1080]: ioctl(s, SIOCGIFADDR, ...): No such device
Apr 25 02:55:59 pppd[326]: Timeout waiting for PADO packets
Apr 25 02:57:14 pppd[326]: Timeout waiting for PADO packets
Apr 25 02:57:14 pppd[326]: Connected to a0:f3:e4:78:a7:77 via interface eth2.1.1
Apr 25 02:57:14 pppd[326]: Connect: ppp0 <--> eth2.1.1
Apr 25 02:57:14 pppd[326]: CHAP authentication succeeded
Apr 25 02:57:14 pppd[326]: peer from calling number A0:F3:E4:78:A7:77 authorized
Apr 25 02:57:14 pppd[326]: local  IP address 84.92.13.45
Apr 25 02:57:14 pppd[326]: remote IP address 195.166.128.170
Apr 25 02:57:14 pppd[326]: primary  DNS address 212.159.6.10
Apr 25 02:57:14 pppd[326]: secondary DNS address 212.159.6.9
Apr 25 02:57:14 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth2.1.1)!
Apr 25 02:57:14 rc_service: ip-up 1351:notify_rc stop_upnp
Apr 25 02:57:15 miniupnpd[1080]: received signal 15, good-bye
Apr 25 02:57:15 rc_service: ip-up 1351:notify_rc start_upnp
Apr 25 02:57:15 miniupnpd[1380]: HTTP listening on port 38704
Apr 25 02:57:15 miniupnpd[1380]: Listening for NAT-PMP traffic on port 5351
Apr 25 02:57:15 WAN Connection: WAN was restored.
Apr 25 03:30:11 smbd[1386]: [2014/04/25 03:30:11, 0] smbd/sesssetup.c:reply_sesssetup_and_X(1265)
Apr 25 03:30:11 smbd[1386]:  reply_sesssetup_and_X:  Rejecting attempt at SPNEGO session setup when it was not negoitiated.
Apr 25 03:30:14 smbd[1387]: [2014/04/25 03:30:14, 0] smbd/sesssetup.c:reply_sesssetup_and_X(1265)
Apr 25 03:30:14 smbd[1387]:  reply_sesssetup_and_X:  Rejecting attempt at SPNEGO session setup when it was not negoitiated.
Apr 25 07:33:16 WAN Connection: Ethernet link down.
Apr 25 07:33:16 stop_nat_rules: apply the redirect_rules!
Apr 25 07:34:10 pppd[326]: Serial link appears to be disconnected
Apr 25 07:34:16 pppd[326]: Connection terminated.
Apr 25 07:34:16 pppd[326]: Modem hangup
Apr 25 07:34:26 pppd[326]: Connected to a0:f3:e4:78:a7:77 via interface eth2.1.1
Apr 25 07:34:26 pppd[326]: Connect: ppp0 <--> eth2.1.1
Apr 25 07:34:28 pppd[326]: CHAP authentication succeeded
Apr 25 07:34:28 pppd[326]: peer from calling number A0:F3:E4:78:A7:77 authorized
Apr 25 07:34:28 pppd[326]: local  IP address 84.92.13.45
Apr 25 07:34:28 pppd[326]: remote IP address 195.166.128.183
Apr 25 07:34:28 pppd[326]: primary  DNS address 212.159.6.10
Apr 25 07:34:28 pppd[326]: secondary DNS address 212.159.6.9
Apr 25 07:34:28 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth2.1.1)!
Apr 25 07:34:29 rc_service: ip-up 1417:notify_rc stop_upnp
Apr 25 07:34:29 miniupnpd[1380]: received signal 15, good-bye
Apr 25 07:34:29 rc_service: ip-up 1417:notify_rc start_upnp
Apr 25 07:34:29 miniupnpd[1446]: HTTP listening on port 49218
Apr 25 07:34:29 miniupnpd[1446]: Listening for NAT-PMP traffic on port 5351
Apr 25 07:34:32 WAN Connection: WAN was restored.
Apr 25 10:31:04 kernel: ERROR!!! CntlEnqueueForRecv: BlockAck Request frame length size = 26 incorrect
Apr 25 11:09:59 miniupnpd[1446]: send(res_buf): Connection reset by peer
Apr 25 11:11:00 smbd[1468]: [2014/04/25 11:11:00, 0] smbd/sesssetup.c:reply_sesssetup_and_X(1265)
Apr 25 11:11:00 smbd[1468]:  reply_sesssetup_and_X:  Rejecting attempt at SPNEGO session setup when it was not negoitiated.
Apr 25 11:11:01 smbd[1469]: [2014/04/25 11:11:01, 0] smbd/sesssetup.c:reply_sesssetup_and_X(1265)
Apr 25 11:11:01 smbd[1469]:  reply_sesssetup_and_X:  Rejecting attempt at SPNEGO session setup when it was not negoitiated.
Apr 25 15:07:19 smbd[1489]: [2014/04/25 15:07:19, 0] smbd/sesssetup.c:reply_sesssetup_and_X(1265)
Apr 25 15:07:19 smbd[1489]:  reply_sesssetup_and_X:  Rejecting attempt at SPNEGO session setup when it was not negoitiated.
Apr 25 15:07:19 smbd[1490]: [2014/04/25 15:07:19, 0] smbd/sesssetup.c:reply_sesssetup_and_X(1265)
Apr 25 15:07:19 smbd[1490]:  reply_sesssetup_and_X:  Rejecting attempt at SPNEGO session setup when it was not negoitiated.
Apr 25 15:36:12 smbd[1493]: [2014/04/25 15:36:12, 0] smbd/sesssetup.c:reply_sesssetup_and_X(1265)
Apr 25 15:36:12 smbd[1493]:  reply_sesssetup_and_X:  Rejecting attempt at SPNEGO session setup when it was not negoitiated.
Apr 25 15:36:12 smbd[1494]: [2014/04/25 15:36:12, 0] smbd/sesssetup.c:reply_sesssetup_and_X(1265)
Apr 25 15:36:12 smbd[1494]:  reply_sesssetup_and_X:  Rejecting attempt at SPNEGO session setup when it was not negoitiated.
Apr 25 19:33:41 smbd[1517]: [2014/04/25 19:33:41, 0] smbd/sesssetup.c:reply_sesssetup_and_X(1265)
Apr 25 19:33:41 smbd[1517]:  reply_sesssetup_and_X:  Rejecting attempt at SPNEGO session setup when it was not negoitiated.
Apr 25 19:33:41 smbd[1518]: [2014/04/25 19:33:41, 0] smbd/sesssetup.c:reply_sesssetup_and_X(1265)
Apr 25 19:33:41 smbd[1518]:  reply_sesssetup_and_X:  Rejecting attempt at SPNEGO session setup when it was not negoitiated.
Apr 26 06:20:21 smbd[1575]: [2014/04/26 06:20:21, 0] smbd/sesssetup.c:reply_sesssetup_and_X(1265)
Apr 26 06:20:21 smbd[1575]:  reply_sesssetup_and_X:  Rejecting attempt at SPNEGO session setup when it was not negoitiated.
Apr 26 06:20:24 smbd[1576]: [2014/04/26 06:20:24, 0] smbd/sesssetup.c:reply_sesssetup_and_X(1265)
Apr 26 06:20:24 smbd[1576]:  reply_sesssetup_and_X:  Rejecting attempt at SPNEGO session setup when it was not negoitiated.
Apr 26 06:58:23 smbd[1582]: [2014/04/26 06:58:23, 0] smbd/sesssetup.c:reply_sesssetup_and_X(1265)
Apr 26 06:58:23 smbd[1582]:  reply_sesssetup_and_X:  Rejecting attempt at SPNEGO session setup when it was not negoitiated.
Apr 26 06:58:26 smbd[1583]: [2014/04/26 06:58:26, 0] smbd/sesssetup.c:reply_sesssetup_and_X(1265)
Apr 26 06:58:26 smbd[1583]:  reply_sesssetup_and_X:  Rejecting attempt at SPNEGO session setup when it was not negoitiated.
Apr 26 10:05:40 smbd[1602]: [2014/04/26 10:05:40, 0] smbd/sesssetup.c:reply_sesssetup_and_X(1265)
Apr 26 10:05:40 smbd[1602]:  reply_sesssetup_and_X:  Rejecting attempt at SPNEGO session setup when it was not negoitiated.
Apr 26 10:05:40 smbd[1603]: [2014/04/26 10:05:40, 0] smbd/sesssetup.c:reply_sesssetup_and_X(1265)
Apr 26 10:05:40 smbd[1603]:  reply_sesssetup_and_X:  Rejecting attempt at SPNEGO session setup when it was not negoitiated.
Apr 26 12:48:05 smbd[1622]: [2014/04/26 12:48:05, 0] smbd/sesssetup.c:reply_sesssetup_and_X(1265)
Apr 26 12:48:05 smbd[1622]:  reply_sesssetup_and_X:  Rejecting attempt at SPNEGO session setup when it was not negoitiated.
Apr 26 12:48:08 smbd[1623]: [2014/04/26 12:48:08, 0] smbd/sesssetup.c:reply_sesssetup_and_X(1265)
Apr 26 12:48:08 smbd[1623]:  reply_sesssetup_and_X:  Rejecting attempt at SPNEGO session setup when it was not negoitiated.
Apr 26 19:46:04 smbd[1660]: [2014/04/26 19:46:04, 0] smbd/sesssetup.c:reply_sesssetup_and_X(1265)
Apr 26 19:46:04 smbd[1660]:  reply_sesssetup_and_X:  Rejecting attempt at SPNEGO session setup when it was not negoitiated.
Apr 26 19:46:04 smbd[1661]: [2014/04/26 19:46:04, 0] smbd/sesssetup.c:reply_sesssetup_and_X(1265)
Apr 26 19:46:04 smbd[1661]:  reply_sesssetup_and_X:  Rejecting attempt at SPNEGO session setup when it was not negoitiated.
Apr 26 20:45:23 pppd[326]: Serial link appears to be disconnected.
Apr 26 20:45:28 WAN Connection: Fail to connect with some issues.
Apr 26 20:45:28 stop_nat_rules: apply the redirect_rules!
Apr 26 20:45:28 WAN Connection: Ethernet link down.
Apr 26 20:45:29 pppd[326]: Connection terminated.
Apr 26 20:45:30 pppd[326]: Modem hangup
Apr 26 20:46:04 miniupnpd[1446]: ioctl(s, SIOCGIFADDR, ...): No such device
Apr 26 20:46:30 pppd[326]: Timeout waiting for PADS packets
Apr 26 20:47:05 pppd[326]: Timeout waiting for PADO packets
Apr 26 20:47:20 pppd[326]: Connected to a0:f3:e4:78:a7:77 via interface eth2.1.1
Apr 26 20:47:20 pppd[326]: Connect: ppp0 <--> eth2.1.1
Apr 26 20:47:50 pppd[326]: LCP: timeout sending Config-Requests
Apr 26 20:47:50 pppd[326]: Connection terminated.
Apr 26 20:47:50 pppd[326]: Modem hangup
Apr 26 20:48:35 pppd[326]: Timeout waiting for PADO packets
Apr 26 20:49:10 pppd[326]: Connected to a0:f3:e4:78:a7:77 via interface eth2.1.1
Apr 26 20:49:10 pppd[326]: Connect: ppp0 <--> eth2.1.1
Apr 26 20:49:11 pppd[326]: CHAP authentication succeeded
Apr 26 20:49:11 pppd[326]: peer from calling number A0:F3:E4:78:A7:77 authorized
Apr 26 20:49:11 pppd[326]: local  IP address 84.92.13.45
Apr 26 20:49:11 pppd[326]: remote IP address 195.166.128.190
Apr 26 20:49:11 pppd[326]: primary  DNS address 212.159.6.10
Apr 26 20:49:11 pppd[326]: secondary DNS address 212.159.6.9
Apr 26 20:49:11 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth2.1.1)!
Apr 26 20:49:11 rc_service: ip-up 1682:notify_rc stop_upnp
Apr 26 20:49:11 miniupnpd[1446]: received signal 15, good-bye
Apr 26 20:49:11 rc_service: ip-up 1682:notify_rc start_upnp
Apr 26 20:49:11 miniupnpd[1711]: HTTP listening on port 59309
Apr 26 20:49:11 miniupnpd[1711]: Listening for NAT-PMP traffic on port 5351
Apr 26 20:49:16 WAN Connection: WAN was restored.
Can anyone see anything that might be making the connection  yoyo up n down like it has been doing Its like this for the last few days I have gone back in?
Any help welcomed..
Osh
OshB5
Re: Opps Talked to soon Asus DSL-N55u Problem
Hi
Also have just seen that one other setting is set to LLC and not VC-Mux
So thats another problem is it not?
And I am not sure about the Service catogary but that is set to "UBR Without PCR
Regs Osh
Fixes: 77
Hi, please see my reply to your other post here: http://community.plus.net/forum/index.php/topic,126530.0.html
Looks like it might be worth trying out another router at this juncture.
 Adam Walker
OshB5
Hi Adam Are you getting me mixed up with someone else or have you directed me to the wrong thread? Only that one isby a guy called Afran or something?
Regs Osh..
dick:quote
