Opps Talked to soon Asus DSL-N55u Problem
- Opps Talked to soon Asus DSL-N55u Problem
26-04-2014 10:08 PM
Hi All
It looks Like I have a problem with this Modem/Router. I just noticed that it had gone down. So I checked back in the history and it looks like its been going down quite a lot But as its been coming back up I have not noticed it till just. Here is a dump of todays Sys Log
Could it be that the setting of PPPoE that I have still got set is causing this to happen?
Apr 25 00:17:56 smbd[1322]: reply_sesssetup_and_X: Rejecting attempt at SPNEGO session setup when it was not negoitiated.
Apr 25 00:17:56 smbd[1323]: [2014/04/25 00:17:56, 0] smbd/sesssetup.c:reply_sesssetup_and_X(1265)
Apr 25 00:17:56 smbd[1323]: reply_sesssetup_and_X: Rejecting attempt at SPNEGO session setup when it was not negoitiated.
Apr 25 02:54:37 WAN Connection: Ethernet link down.
Apr 25 02:54:37 stop_nat_rules: apply the redirect_rules!
Apr 25 02:55:08 pppd[326]: Serial link appears to be disconnected.
Apr 25 02:55:14 pppd[326]: Connection terminated.
Apr 25 02:55:14 pppd[326]: Modem hangup
Apr 25 02:55:15 miniupnpd[1080]: ioctl(s, SIOCGIFADDR, ...): No such device
Apr 25 02:55:18 miniupnpd[1080]: ioctl(s, SIOCGIFADDR, ...): No such device
Apr 25 02:55:59 pppd[326]: Timeout waiting for PADO packets
Apr 25 02:57:14 pppd[326]: Timeout waiting for PADO packets
Apr 25 02:57:14 pppd[326]: Connected to a0:f3:e4:78:a7:77 via interface eth2.1.1
Apr 25 02:57:14 pppd[326]: Connect: ppp0 <--> eth2.1.1
Apr 25 02:57:14 pppd[326]: CHAP authentication succeeded
Apr 25 02:57:14 pppd[326]: peer from calling number A0:F3:E4:78:A7:77 authorized
Apr 25 02:57:14 pppd[326]: local IP address 84.92.13.45
Apr 25 02:57:14 pppd[326]: remote IP address 195.166.128.170
Apr 25 02:57:14 pppd[326]: primary DNS address 212.159.6.10
Apr 25 02:57:14 pppd[326]: secondary DNS address 212.159.6.9
Apr 25 02:57:14 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth2.1.1)!
Apr 25 02:57:14 rc_service: ip-up 1351:notify_rc stop_upnp
Apr 25 02:57:15 miniupnpd[1080]: received signal 15, good-bye
Apr 25 02:57:15 rc_service: ip-up 1351:notify_rc start_upnp
Apr 25 02:57:15 miniupnpd[1380]: HTTP listening on port 38704
Apr 25 02:57:15 miniupnpd[1380]: Listening for NAT-PMP traffic on port 5351
Apr 25 02:57:15 WAN Connection: WAN was restored.
Apr 25 03:30:11 smbd[1386]: [2014/04/25 03:30:11, 0] smbd/sesssetup.c:reply_sesssetup_and_X(1265)
Apr 25 03:30:11 smbd[1386]: reply_sesssetup_and_X: Rejecting attempt at SPNEGO session setup when it was not negoitiated.
Apr 25 03:30:14 smbd[1387]: [2014/04/25 03:30:14, 0] smbd/sesssetup.c:reply_sesssetup_and_X(1265)
Apr 25 03:30:14 smbd[1387]: reply_sesssetup_and_X: Rejecting attempt at SPNEGO session setup when it was not negoitiated.
Apr 25 07:33:16 WAN Connection: Ethernet link down.
Apr 25 07:33:16 stop_nat_rules: apply the redirect_rules!
Apr 25 07:34:10 pppd[326]: Serial link appears to be disconnected
Apr 25 07:34:16 pppd[326]: Connection terminated.
Apr 25 07:34:16 pppd[326]: Modem hangup
Apr 25 07:34:26 pppd[326]: Connected to a0:f3:e4:78:a7:77 via interface eth2.1.1
Apr 25 07:34:26 pppd[326]: Connect: ppp0 <--> eth2.1.1
Apr 25 07:34:28 pppd[326]: CHAP authentication succeeded
Apr 25 07:34:28 pppd[326]: peer from calling number A0:F3:E4:78:A7:77 authorized
Apr 25 07:34:28 pppd[326]: local IP address 84.92.13.45
Apr 25 07:34:28 pppd[326]: remote IP address 195.166.128.183
Apr 25 07:34:28 pppd[326]: primary DNS address 212.159.6.10
Apr 25 07:34:28 pppd[326]: secondary DNS address 212.159.6.9
Apr 25 07:34:28 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth2.1.1)!
Apr 25 07:34:29 rc_service: ip-up 1417:notify_rc stop_upnp
Apr 25 07:34:29 miniupnpd[1380]: received signal 15, good-bye
Apr 25 07:34:29 rc_service: ip-up 1417:notify_rc start_upnp
Apr 25 07:34:29 miniupnpd[1446]: HTTP listening on port 49218
Apr 25 07:34:29 miniupnpd[1446]: Listening for NAT-PMP traffic on port 5351
Apr 25 07:34:32 WAN Connection: WAN was restored.
Apr 25 10:31:04 kernel: ERROR!!! CntlEnqueueForRecv: BlockAck Request frame length size = 26 incorrect
Apr 25 11:09:59 miniupnpd[1446]: send(res_buf): Connection reset by peer
Apr 25 11:11:00 smbd[1468]: [2014/04/25 11:11:00, 0] smbd/sesssetup.c:reply_sesssetup_and_X(1265)
Apr 25 11:11:00 smbd[1468]: reply_sesssetup_and_X: Rejecting attempt at SPNEGO session setup when it was not negoitiated.
Apr 25 11:11:01 smbd[1469]: [2014/04/25 11:11:01, 0] smbd/sesssetup.c:reply_sesssetup_and_X(1265)
Apr 25 11:11:01 smbd[1469]: reply_sesssetup_and_X: Rejecting attempt at SPNEGO session setup when it was not negoitiated.
Apr 25 15:07:19 smbd[1489]: [2014/04/25 15:07:19, 0] smbd/sesssetup.c:reply_sesssetup_and_X(1265)
Apr 25 15:07:19 smbd[1489]: reply_sesssetup_and_X: Rejecting attempt at SPNEGO session setup when it was not negoitiated.
Apr 25 15:07:19 smbd[1490]: [2014/04/25 15:07:19, 0] smbd/sesssetup.c:reply_sesssetup_and_X(1265)
Apr 25 15:07:19 smbd[1490]: reply_sesssetup_and_X: Rejecting attempt at SPNEGO session setup when it was not negoitiated.
Apr 25 15:36:12 smbd[1493]: [2014/04/25 15:36:12, 0] smbd/sesssetup.c:reply_sesssetup_and_X(1265)
Apr 25 15:36:12 smbd[1493]: reply_sesssetup_and_X: Rejecting attempt at SPNEGO session setup when it was not negoitiated.
Apr 25 15:36:12 smbd[1494]: [2014/04/25 15:36:12, 0] smbd/sesssetup.c:reply_sesssetup_and_X(1265)
Apr 25 15:36:12 smbd[1494]: reply_sesssetup_and_X: Rejecting attempt at SPNEGO session setup when it was not negoitiated.
Apr 25 19:33:41 smbd[1517]: [2014/04/25 19:33:41, 0] smbd/sesssetup.c:reply_sesssetup_and_X(1265)
Apr 25 19:33:41 smbd[1517]: reply_sesssetup_and_X: Rejecting attempt at SPNEGO session setup when it was not negoitiated.
Apr 25 19:33:41 smbd[1518]: [2014/04/25 19:33:41, 0] smbd/sesssetup.c:reply_sesssetup_and_X(1265)
Apr 25 19:33:41 smbd[1518]: reply_sesssetup_and_X: Rejecting attempt at SPNEGO session setup when it was not negoitiated.
Apr 26 06:20:21 smbd[1575]: [2014/04/26 06:20:21, 0] smbd/sesssetup.c:reply_sesssetup_and_X(1265)
Apr 26 06:20:21 smbd[1575]: reply_sesssetup_and_X: Rejecting attempt at SPNEGO session setup when it was not negoitiated.
Apr 26 06:20:24 smbd[1576]: [2014/04/26 06:20:24, 0] smbd/sesssetup.c:reply_sesssetup_and_X(1265)
Apr 26 06:20:24 smbd[1576]: reply_sesssetup_and_X: Rejecting attempt at SPNEGO session setup when it was not negoitiated.
Apr 26 06:58:23 smbd[1582]: [2014/04/26 06:58:23, 0] smbd/sesssetup.c:reply_sesssetup_and_X(1265)
Apr 26 06:58:23 smbd[1582]: reply_sesssetup_and_X: Rejecting attempt at SPNEGO session setup when it was not negoitiated.
Apr 26 06:58:26 smbd[1583]: [2014/04/26 06:58:26, 0] smbd/sesssetup.c:reply_sesssetup_and_X(1265)
Apr 26 06:58:26 smbd[1583]: reply_sesssetup_and_X: Rejecting attempt at SPNEGO session setup when it was not negoitiated.
Apr 26 10:05:40 smbd[1602]: [2014/04/26 10:05:40, 0] smbd/sesssetup.c:reply_sesssetup_and_X(1265)
Apr 26 10:05:40 smbd[1602]: reply_sesssetup_and_X: Rejecting attempt at SPNEGO session setup when it was not negoitiated.
Apr 26 10:05:40 smbd[1603]: [2014/04/26 10:05:40, 0] smbd/sesssetup.c:reply_sesssetup_and_X(1265)
Apr 26 10:05:40 smbd[1603]: reply_sesssetup_and_X: Rejecting attempt at SPNEGO session setup when it was not negoitiated.
Apr 26 12:48:05 smbd[1622]: [2014/04/26 12:48:05, 0] smbd/sesssetup.c:reply_sesssetup_and_X(1265)
Apr 26 12:48:05 smbd[1622]: reply_sesssetup_and_X: Rejecting attempt at SPNEGO session setup when it was not negoitiated.
Apr 26 12:48:08 smbd[1623]: [2014/04/26 12:48:08, 0] smbd/sesssetup.c:reply_sesssetup_and_X(1265)
Apr 26 12:48:08 smbd[1623]: reply_sesssetup_and_X: Rejecting attempt at SPNEGO session setup when it was not negoitiated.
Apr 26 19:46:04 smbd[1660]: [2014/04/26 19:46:04, 0] smbd/sesssetup.c:reply_sesssetup_and_X(1265)
Apr 26 19:46:04 smbd[1660]: reply_sesssetup_and_X: Rejecting attempt at SPNEGO session setup when it was not negoitiated.
Apr 26 19:46:04 smbd[1661]: [2014/04/26 19:46:04, 0] smbd/sesssetup.c:reply_sesssetup_and_X(1265)
Apr 26 19:46:04 smbd[1661]: reply_sesssetup_and_X: Rejecting attempt at SPNEGO session setup when it was not negoitiated.
Apr 26 20:45:23 pppd[326]: Serial link appears to be disconnected.
Apr 26 20:45:28 WAN Connection: Fail to connect with some issues.
Apr 26 20:45:28 stop_nat_rules: apply the redirect_rules!
Apr 26 20:45:28 WAN Connection: Ethernet link down.
Apr 26 20:45:29 pppd[326]: Connection terminated.
Apr 26 20:45:30 pppd[326]: Modem hangup
Apr 26 20:46:04 miniupnpd[1446]: ioctl(s, SIOCGIFADDR, ...): No such device
Apr 26 20:46:30 pppd[326]: Timeout waiting for PADS packets
Apr 26 20:47:05 pppd[326]: Timeout waiting for PADO packets
Apr 26 20:47:20 pppd[326]: Connected to a0:f3:e4:78:a7:77 via interface eth2.1.1
Apr 26 20:47:20 pppd[326]: Connect: ppp0 <--> eth2.1.1
Apr 26 20:47:50 pppd[326]: LCP: timeout sending Config-Requests
Apr 26 20:47:50 pppd[326]: Connection terminated.
Apr 26 20:47:50 pppd[326]: Modem hangup
Apr 26 20:48:35 pppd[326]: Timeout waiting for PADO packets
Apr 26 20:49:10 pppd[326]: Connected to a0:f3:e4:78:a7:77 via interface eth2.1.1
Apr 26 20:49:10 pppd[326]: Connect: ppp0 <--> eth2.1.1
Apr 26 20:49:11 pppd[326]: CHAP authentication succeeded
Apr 26 20:49:11 pppd[326]: peer from calling number A0:F3:E4:78:A7:77 authorized
Apr 26 20:49:11 pppd[326]: local IP address 84.92.13.45
Apr 26 20:49:11 pppd[326]: remote IP address 195.166.128.190
Apr 26 20:49:11 pppd[326]: primary DNS address 212.159.6.10
Apr 26 20:49:11 pppd[326]: secondary DNS address 212.159.6.9
Apr 26 20:49:11 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth2.1.1)!
Apr 26 20:49:11 rc_service: ip-up 1682:notify_rc stop_upnp
Apr 26 20:49:11 miniupnpd[1446]: received signal 15, good-bye
Apr 26 20:49:11 rc_service: ip-up 1682:notify_rc start_upnp
Apr 26 20:49:11 miniupnpd[1711]: HTTP listening on port 59309
Apr 26 20:49:11 miniupnpd[1711]: Listening for NAT-PMP traffic on port 5351
Apr 26 20:49:16 WAN Connection: WAN was restored.
Can anyone see anything that might be making the connection yoyo up n down like it has been doing Its like this for the last few days I have gone back in?
Any help welcomed..
Osh
Any help welcomed..
Osh
Message 1 of 4
(4,339 Views)
3 REPLIES 3
Re: Opps Talked to soon Asus DSL-N55u Problem
27-04-2014 12:44 AM
Hi
Also have just seen that one other setting is set to LLC and not VC-Mux
So thats another problem is it not?
And I am not sure about the Service catogary but that is set to "UBR Without PCR
Regs Osh
Regs Osh
Message 2 of 4
(802 Views)
28-04-2014 10:50 AM
Hi, please see my reply to your other post here: http://community.plus.net/forum/index.php/topic,126530.0.html
Looks like it might be worth trying out another router at this juncture.
Message 3 of 4
(802 Views)
04-05-2014 6:17 PM
Hi Adam Are you getting me mixed up with someone else or have you directed me to the wrong thread? Only that one isby a guy called Afran or something?
Regs Osh..
dick:quote
Regs Osh..
dick:quote
Message 4 of 4
(802 Views)
