Openreach fiber modem....Do we really need it?
- Openreach fiber modem....Do we really need it?
11-12-2012 4:45 AM
I.E a router and modem all in one like Thomsons used to be?
all this openreach crap is... is a switch to convert RJ11 to RJ45.... so its using power and im having to pay for crap i dont wanna be using ....
For a RJ11 to RJ45 converter its stupidly big and im powering 2 devices when i dont really need to... and at the mo i have no choice but to use and yet i dont own the item BT do and i have to pa their electric bill?
Re: Openreach fiber modem....Do we really need it?
11-12-2012 7:11 AM
11-12-2012 7:29 AM
This device says, I think, that it incorporates a VDSL modem http://www.billion.com/product/vdsl2/BiPAC8200N-wireless-N-VDSL2-firewall-router.html so you might be able to use it in place of both the supplied boxes (if this is allowed).
11-12-2012 7:44 AM
11-12-2012 4:39 PM
Quote from: w23 This also incorporates a VDSL2 modem (and a whole lot more): http://www.fritzbox.eu/en/products/FRITZBox_Fon_WLAN_7390/index.php?tab=1 and yes, it works on Plusnet FTTC
You would need to save a lot of electricity to pay for that
11-12-2012 4:42 PM
11-12-2012 5:38 PM
if you all plusnet you get told you have to use the BT modem
i get charged line rental then i have to pay for their equipment
fair enough its not too much but left on 24/7/365 soon adds up
11-12-2012 8:19 PM
11-12-2012 9:00 PM
If you choose to take a fibre service (from us or any other ISP) then surely you're agreeing to pay for the electricity on the equipment to receive the service into your house? Supplying equipment to receive a service is something that we and pretty much every other ISP do. This has been the same on ADSL for many many years.
11-12-2012 10:06 PM
12-12-2012 9:30 AM
13-12-2012 9:15 AM
congrats again BT
13-12-2012 11:30 AM
i havent tried it as its a bit over my head and i might mess it up lol
i want to use it to cut out the middleman when using my ps3 (using the second ethernet port) so i can get a nat 1
if you want wireless then you will have to use a router with it
13-12-2012 11:34 AM
Quote it is junk when the bt engi that instaled ur fiber gives u the wrong moem so for the last 6 months i have faulty/incorrect equiptment
I'm not sure that a fault modem means it's the wrong piece of kit. Any electrical item can become faulty.
13-12-2012 8:37 PM
Quote from: flaminmoses i want to use it to cut out the middleman when using my ps3 (using the second ethernet port) so i can get a nat 1
The LAN 2 port is disabled on the OR modem.
