Openreach engineer just visited slow download speeds
richardhead
Good afternoon,
As mentioned above, an engineer has visited as we have had no phone or internet for a week and he has redone the line to the cabinet box.
The phone and internet is now working but we have download speeds of 283kbps, instead of around 6-8000.
The router stats are saying that the snr is at 19.3DB (previously it was at around 6-8DB before the line went), I'm not sure if perhaps where it's higher if this is the cause.
I have rebooted the router and it is still the same. I have uploaded my router stats below.
I would greatly appreciate your help. Thank you.
Fixes: 229
Re: Openreach engineer just visited slow download speeds
I suspect your line just needs a reset.
We'll get that done now
 Matthew Wheeler
richardhead
Wow thanks for such a quick reply Matthew!. Is it because the snr is to high?.
Fixes: 229
Your speeds will have been restricted by DLM because of your phone fault.
If you test the line in the next 15 minutes the speed should be higher.
 Matthew Wheeler
richardhead
I have just tested and the speeds are back to normal. Thanks you very much Matthew for your fantastic response time!, have a great new year!!!.
Fixes: 238
Moderator's note by Mike (Mav): I have changed the fix to @MatthewWheeler as per message #2
Forum Moderator and Customer
Fixes: 229
Glad to hear it!
 Matthew Wheeler
