Openreach cut off my phone and broadband
wufer
On 23 May,openreach were working on the pole outside my house.
After he had left, I found out my broadband and my house phone were both disconnect
They both worked fine before openreach came.
So now I have no phone line connected for my broadband or home phone
I suspect the openreach worker made a mistake when he was working up the pole
Can a member of Plusnet staff please get in touch with me to sort it out
Cheers
10 REPLIES 10
Mustrum
Fixes: 77
Re: Openreach cut off my phone and broadband
Why wait, just report a fault, it will be quicker - probably.
RichardB
Seasoned Champion
Fixes: 39
wufer
Yes,thank you both.
I've done that.
A fault was found and will be fixed by 30 May
Cheers
wufer
So the engineer fixed the problem up the pole and now I have my phone back on
I also have my broadband back on But no internet
When I look at my TG582N, the power, broadband and my wi fi are all green.
But my internet is red.
When I try to go online, it takes me to that gateway where you have to put your user name and password in
So what name and password for the want
I've tried one for getting into this forum,and I've tried the one I use to sign into Plusnet, but they don't work.Ive tried my user name together with the password on the back of the router but that won't work
Help
Cheers
Fixes: 1,484
It's the username and password that you sign into the PN member centre with.
The format for the username is username@plusdsl.net
wufer
I did what Dvorak told me, and the router still not accepting it.
So, as I say,power, broadband WiFi all green, but internet still red.
No access to the internet since 23 May
Can any Plusnet staff jump on and help?
Cheers
pvmb
With a TG582n router, have you logged in to it and looked at the page where you check Internet Connection status - and also restart the Internet connection?
wufer
No,that's the point, I can't log in to the router.
I used, wufer@plusdsl.net.....and my password, but the router says there wrong.
So I can't log into my router.
Legend
Fixes: 255
Deleted - posted in error.
RichardB
Seasoned Champion
Fixes: 39
Hi wufer,
The username & password to login to the router are detailed at:
https://www.plus.net/help/broadband/router-user-guides/582n/#582n-find-username-and-password
More TG582n info at:
Regards
Richard
