Openreach Stop Sell & No Fibre
Tashaxprince
I have just moved home and my plusnet wifi was due to transfer this week. I had to be moved onto a non-fibre plan as my new area doesn’t have fibre. Today I’ve received an email from plusnet to say they can’t go ahead with my new package as planned due to Openreach Stop Sell (copper wires). I am worried that as I also don’t have access to fibre, there won’t be a wifi option for me. I can’t seem to find out online. Does anyone know what an alternative would be?
20 REPLIES 20
Fixes: 89
Re: Openreach Stop Sell & No Fibre
@Tashaxprince
First question is what package were you on before?
Use the Checker shown below to see what's available to you. If you can post a screen image of the results (hiding your personal details) then the Forum may be able to offer suggestions.
To include the screen iamge on a reply click on the icon that looks like a rectangle with a mounain in it.
You my need to phone PN to find out what's happening. You could try the PlusNet Customer Options Team on 0800 013 2632
Fixes: 531
@Tashaxprince  to Openreach Stop Sell (copper wires)
there isn't a stop sell on copper wires! There's a stop sell on copper based phone services, but broadband will still be supplied over copper for a long time yet in many areas.
As @bmc says , let's see the btw checker results...
Tashaxprince
Hi Brian
I previously had unlimited fibre broadband.
Unfortunately, I don’t have any of the information required to fill in the link you have sent.
Thank you for your reply all the same
Tashaxprince
Yes apologies, still wrapping my head around it! I don’t have any of the information to fill in the link. There’s no landline, and the website to find my UPRN won’t let me on.
Fixes: 334
Just use this link: https://www.broadbandchecker.btwholesale.com/#/ADSL/AddressHome and select your address from the drop-down.
Tashaxprince
I managed to get the links to work but I have no option to attach the photo as you describe - I will paste below:
FTTP is not available.
The exchange is not in a current fibre priority programme
As a WLR withdrawal exchange, product restrictions apply
SOADSL is not restricted at the exchange
Fixes: 89
@Tashaxprince
Try the address version of the Checker.
You are probably on a SOGEA connection. This is fibre to the FTTC cabinet an then the copper wire to your premise.
Edit : Just saw your latest post. I think you need to phone PN Support as Forum members won't be able to sort this out.
Fixes: 334
Are you using a mobile device? If so, select the 'desktop' version of the site, and you will then have the option to insert the screenshot.
Tashaxprince
Okay thank you all the same everyone, I will wait for PN to get back to me.
Fixes: 89
@Tashaxprince
Just had another thought.
Have another look at the Checker. I believe "Fibre" shows up as WBC VDSL (which is FTTC). If you look to the right does it say Available or Waiting List.
Tashaxprince
It says WBC FTTC ‘unavailable’. Further down it says VDSL Multicast ‘available’
Fixes: 531
@Tashaxprince at the top of the availability results does it show something like this
If so, what does it say in the WBC SoGEA availability column ?
Tashaxprince
It says available for that one!
Fixes: 89
@Tashaxprince
Now that I remember what the results look like I can comment. It would still be good to see an actual screen image.
WBC FTTC is the old product which could include a landline. Now that OpenReach have introduced the Stop/Sell this is no longer available.
WBC SOGEA in the new internet only product introduced to replace WBC FTTP. If It says Available then that is not the reason for your order problems. Has it said Waiting List then PN couldn't place an order due to no "ports" being available in the Cabinet.
