Open reach modem and air port extreme router
D3lbou
So I have the PN router but
Was wondering if I can just cut the middle man and
Hook up the AirPort Extreme to the open reach modem
Like this
http://www.yourmacteacher.com/using-apple-time-capsule-or-airport-with-bt-infinity/
Is it possible as I don't really want 1 modem and 2 routers working
One of each would be better
Many thanks
Fixes: 46
Re: Open reach modem and air port extreme router
Yes, it will work fine. You will need to configure the PPPoE connection on the Airport with your PlusNet username and password as described here http://www.plus.net/support/broadband/hardware/broadband-connection-settings.shtml .
Note that link seems to imply you don't need a password for PPPoE but it's wrong, you do! it's the same as the one described for PPPoA.
D3lbou
Thanks mister w for the quick reply
that's great to know
Many thanks
Fixes: 154
Hi D3lboy,
I'm successfully using the Openreach modem with an Airport Extreme and have no issues.
Hope you get on OK Smiley
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
D3lbou
Thanks Dvorak
Wish I knew before I ordered there router could have saved £5.99  lol
Oh well always something to fall back on
Fixes: 154
Yeah it's good to have a spare around in case there are any issues in future, it will help to prove whether it's your router or connection.
