Open DNS or New Router
- Open DNS or New Router
21-06-2010 8:10 PM
Hi very new to pulsnet but iv always used Open DNS with my router's but just noticed the Thomson router surplied
does not make it very easy to do... I have a Netgear from Sky thats been flashed can i use that instead .... Or do i need
to change settings in that for it to work on Pulsnet Kind regards Ki
Message 1 of 8
(1,066 Views)
7 REPLIES 7
Re: Open DNS or New Router
21-06-2010 9:01 PM
Hi Ki,
Have you had a look here? http://community.plus.net/library/dns/how-to-change-the-default-dns-servers-in-a-thomson-speedtouch-...
Jojo
Jojo
Message 2 of 8
(535 Views)
21-06-2010 9:30 PM
If the Sky unit will allow you to input the Plusnet settings then it may well work and if it does (and is a Netgear DG834GT) it is a better router than the 585v7
Message 3 of 8
(535 Views)
21-06-2010 10:01 PM
Wouldn't it be easier to set the DNS servers in the Internet Protocol (TCP/IP) properties on the PC? AIUI that would override the router settings.
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
Message 4 of 8
(535 Views)
21-06-2010 10:33 PM
Ok i would like to use Netgear DG834GT so i can sett it to Open DNS
Could some one walk me through what i have to do to put Pulsnet
settings in .... to connect to the internet with the Netgear DG834GT
as i belive that there a better router to use ........... thank you
Message 5 of 8
(535 Views)
21-06-2010 10:36 PM
If you go to basic setting on the router you should be able to input your settings
http://www.plus.net/support/broadband/help_and_setup/connections_settings.shtml
Message 6 of 8
(535 Views)
21-06-2010 10:50 PM
Thank you this ill be of great help ill try tomorrow will let you know how it goes
Message 7 of 8
(535 Views)
23-06-2010 8:00 PM
Thank you
* Oldjim
For the link about router settings everything went smoothly and no i can use Open DNS too so the
pings have dropped which is good hoping it fixes the Skype problem to fingers crossed
* Oldjim
Message 8 of 8
(535 Views)
