Oops, not trusted, never seen before :(
TORPC
Using https://dsldevice.lan
On the TG582n with USB
I am now seeing
In FireFox
In Iron
IE
9 REPLIES 9
RickK
Re: Oops, not trusted, never seen before :(
Cleared your Firefox preferences?
As in theory every browser should give you that error because Self-Signed certificates (so a certificate that is created by itself) are never publicly trusted in browsers.
Pettitto
Fixes: 5
That's just the local certificate for your router - nothing to worry about.
Just add this certificate as an exception and that should do the trick.
TORPC
I  know it is safe
However I have never seen it before today
& wondered if anyone else have seen this latest behaviour
Oldjim
Resting Legend
Fixes: 63
That is probably because you have started using https instead of http
TORPC
Cor blimey
OJ, did you have the eagle(s) breakfast this morning
Well spotted, as I did not realise the obvious
Tested with plain old HTTP rather than HTTP(S) & it goes straight to http://dsldevice.lan/login.lp
Cheers OJ Smiley
picbits
This was mentioned by another member a couple of days ago.
http://community.plus.net/forum/index.php/topic,125785.msg1093301.html#msg1093301
TORPC
Cheers DomS
I dont know how I  Embarrassed missed that one
elsinor5
That is exactly what im am getting. Im glad im not the only one with this. When I rang PN to discuss it they had no clue what would have caused it and had never heard of the issue before.
Strange how we get 2 instances of the same unique situation in less than 4 days. Surely either this is an issue that started last weekend or it happens a lot more often than thought.
My concern was why it suddenly started.
I had been logging in and out of the router all weekend with no problem.
Then for no reason this appears on both the machines I have. Nothing had changed in the way I had been trying to log in, so why the sudden certificate error.
If we now understand what the cause is, can someone please walk me through how to clear it.
Many thanks
I
TORPC
Hi elisnor
In my case, it looks like
I inadvertently &  Embarrassed added the (S) to HTTP(S) rather than plain HTTP
Should of known better
