Ooer...what happened here?
- Ooer...what happened here?
26-10-2012 1:03 PM
Anyone got any ideas what could have caused these three huge blocks of red? I don't remember anything happening at 10pm so it was probably of short duration.
- Curious Dave
- Curious Dave
A tortoise? What's that?
You know what a turtle is? Same thing.
Message 1 of 2
(682 Views)
1 REPLY 1
Re: Ooer...what happened here?
26-10-2012 2:03 PM
Most likely a blip in the monitoring to be honest - for some reason the pings weren't available. As the graphs look normal either side of the red lines this is the most likely explanation - if they were caused by connection issues you'd be seeing a lot more interference on the graph either side of those.
Message 2 of 2
(343 Views)
