Online gaming high pings, spikes and timing out.
Pr7
Hey for a while now; around the times of 5pm - 9pm weekdays and weekends I get major high pings that seems to spike up from no where and some times I time out of my online sessions, I'm connected to my router via wireless connection. My general browsing and using the internet is fine speed wise, just when it's online gaming.
Is there a way to fix this?
Re: Online gaming high pings, spikes and timing out.
Wireless and gaming so not mix, every electrical gadget close to your router in your house, can give interference degrading your wireless lan speed to your router.  Always play games when wired.
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
Pr7
I tested it wired and still I get high pings and spikes. My ping is good (40 - 60) during the times other then the ones I mentioned in the 1st post.
xreyuk
What are you playing? PC or Console?
If you're on PC, are you sure you're joining UK/Western EU based servers as opposed to ones located in the USA?
Pr7
PC and I only join UK/EU servers.
dick:quote
rongtw
Fixes: 12
have you tried turn  UPNP off in router ?
Pr7
Yes didn't make a difference.
Lagging on games online atm.  Sad
Then what games as there has been a DDos going on since Sunday
Pr7
Mulitple and I don't think it's that.
I had this issue pretty much since i've been with plusnet.
you can't fix a problem if you don't know what it affects, knowing the games help
rongtw
Fixes: 12
i play mostly Bf games and only have a few probs , is your game on the pn list ? http://community.plus.net/forum/index.php/topic,94089.0.html
Pr7
Yes and I still get high pings and spikes.
Pr7
Help...
rongtw
Fixes: 12
which Game PR7 ?
Pr7
Multiple online PC games like I said before the pings are fine unless its around 5pm - 9pm (getting 90 ping atm and spiking).
