Ongoing problems with connection speed
- Ongoing problems with connection speed
25-02-2016 11:26 PM
From previous experience with BT, and initially with Plusnet, my line can support a connection speed of 5-6 Mb.
However, I've been getting regular dips in service quality for several weeks now. On a good day we are getting 0.5 Mb/sec which I don't really think is good enough. Have tried alternative router etc.
From the BT wholesale tests, the IP profile is 0.51 Mbps.
Any advice on this would be greatly appreciated.
Message 1 of 3
(930 Views)
2 REPLIES 2
Re: Ongoing problems with connection speed
25-02-2016 11:30 PM
Hello there. Are these speed tests over a wired connection? If so, I would recommend troubleshooting the fault at http://faults.plus.net and then potentially raise it, so that our faults team can investigate further. if the issue lies with the wireless connectivity, here's a guide to improving the wireless speeds.
http://www.plus.net/support/broadband/wireless_broadband/wireless_signal.shtml
Hope this helps
Hope this helps
This is my personal Community Forum account to help out around these parts while I'm at home. If I'm posting from the 1st March 2020, this means I'm off-duty with no access to internal systems.
Message 2 of 3
(496 Views)
25-02-2016 11:53 PM
thanks for the reply.
I've had problems with both wired and wireless connections. I've gone through the troubleshooting guide and will wait to see if this resolves the problem.
Message 3 of 3
(496 Views)
