Ongoing connection issues, now speed has halved again
- Re: Ongoing connection issues, now speed has halve...
26-03-2016 5:17 PM
My patience is starting to wear thin unfortunately.
Re: Ongoing connection issues, now speed has halved again
28-03-2016 10:20 PM
28-03-2016 10:47 PM
I've always had poor upload on Plusnet, just moved from sky and my upload speed was 1.2mb and I struggle to get 1mb now with the exactly the same setup?
If you Like it, give it a
29-03-2016 7:57 AM
Our upload speed was much better prior up until instability issues started. Are there separate profiles for upstream & downstream?
29-03-2016 8:28 AM
Download speed achieved during the test was - 11.53 Mbps
For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
IP Profile for your line is - 16.79 Mbps
Upload speed achieved during the test was - 0.37Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.45 Mbps
So at some point in the last 3 months, as well as the downstream IP profile rate bouncing around the upstream profile has come down to 0.45Mbps and stuck there.
29-03-2016 8:49 AM
29-03-2016 9:03 AM
29-03-2016 9:35 AM
30-03-2016 7:55 AM
31-03-2016 8:22 AM
There seems to be an issue with the problem reporting/ticket service, in that when you have an ongoing issue such as mine (stability for weeks at a time and then a bout of instability, after which all is OK for a further period of time) you have to create a new ticket every time it happens. The last ticket was closed because the support rep I spoke to said they could keep it open for a month or two while we wait and see if the problem has gone away after the BT Openreach engineer visited. It would make far more sense to be able to keep all the info & history in a single ticket and close it when we are finally sure that the problem no longer exists.
31-03-2016 9:08 AM
31-03-2016 9:13 AM
Edited to add: I can see the SNR is now back at 6.1 from 15, and I'm getting 15.6Mbps download in the speed test. Let's see how long it lasts this time.
