One PC - slow downloads, cut outs, other PC fine
- Re: One PC - slow downloads, cut outs, other PC fi...
12-10-2012 5:40 PM
I have one PC (one year old) on a wired Ethernet into a one year old Netgear router and a second PC (about 4 years old) into the same wired Ethernet network. Both running Win 7 Home Premium 64-bit, with Avast anti-virus.
One year old - download speed averages 3.5-4mb.
4 year old - download speed averages 0.5-1mb
I've tried what I thought might be the obvious things:
> putting each PC through the other's wall ethernet point - same result. Ie it's not the network, nor the router, it's the PC.
> running full anti-virus check on both - cleaned up - same result after
Very frustrating. Any thoughts about what to try next please?
Thanks in advance.
Thanks in advance.
Message 1 of 5
(1,047 Views)
4 REPLIES 4
Re: One PC - slow downloads, cut outs, other PC fine
12-10-2012 6:13 PM
You could try temporarily disabling the Avast! real-time web sheild? It could be that the CPU in the older PC is struggling to cope. I've seen it before with avast.
Message 2 of 5
(597 Views)
13-10-2012 10:01 AM
If it's a PC (rather than a laptop), could you try a cheap PCI network card - you could have a faulty ethernet port.
If it's a laptop you could try a USB ethernet adaptor (that option would also work in a PC of course and could be a useful thing to have around in case of future problems). http://www.amazon.co.uk/s/?ie=UTF8&keywords=usb%2Fethernet+adaptor&tag=googhydr-21&index=electronics... (other sources are available of course).
Call me 'w23'
Message 3 of 5
(597 Views)
13-10-2012 2:40 PM
goto control panel, network connections, change adapter settings, double click your connection, properties, driver settings, set to 100mbps or 1gbps on the duplex setting.
failing that see if there any driver updates
failing that try a pci network card that has been sugguested.
Message 4 of 5
(597 Views)
13-10-2012 7:20 PM
Thanks all for your thoughts.
Tried the duplex and avast settings - no joy. Then remembered I had a USB to RJ45 adapter somewhere, couldn't find the software driver for it (but managed to find one - nearly all in chinese) online - virus checked that one. Installed the software, switched the network cable and it's the same speed as my other one. Ordered a new network card from Amazon - so should be sorted.
Thank you all again for your thoughts and posts . Much appreciated.
Cheers
Cheers
Message 5 of 5
(597 Views)
