Old broadband was not cancelled when switching to plus net fibre
moogaloo
Re: Old broadband was not cancelled when switching to plus net fibre
Quote from: James
I've already raised the issue with the switching page not being clear.
NOT BEING CLEAR! it is just plain wrong, I have been fobbed of on my ticket it seems no investigation was started despite being verbally promised it would.
HPsauce
Seasoned Pro
Fixes: 5
Note that the "right" person has some awareness:
James Bailey
Plusnet Complaints Manager
I'd suggest that meanwhile you need to resolve the situation with Sky completely then work out what, if anything, your losses were compared to what they would have been had you given them notice once you had a confirmed move date.  Wink
moogaloo
Quote from: jelv
OpenReach will have told Sky that you had been disconnected from their service.
That is what plus net are saying, but they seem to be going back on their promise to investigate what has happened.  My worry is that they think it works like ADSL switching and that when switching from ADSL to Fibre BT Openreach actually do nothing with the MAC keys, I would be surprised if I was alone in paying for 2 broadband connections.
I have tried lookoing to see if I can contact BT OpenReach myself, to check the procedure but I have not found away
tonycollinet
2 - We'll contact your provider
This is the easy part. Sit back, relax and leave it with us.
We'll get in touch with your current provider and let you know when we've sorted out your switch date.
I think the phrase "Sit back and leave it with us" suggests quite strongly that the OP does not need to worry, and that plusnet will deal with everything. Pretty clear IMO.
HPsauce
Seasoned Pro
Fixes: 5
Quote from: tonycollinet
Pretty clear IMO.
And of course fundamentally wrong.  Cry
Bright
Who is your phone service with now? The process used (and where it's documented) depends on what's being transferred.
Quote from: HPsauce
Plusnet notifies Sky indirectly via BTOR. I don't think it's quite that clear cut.
jelv
Fixes: 10
Quote from: moogaloo
Forget that - it's OFCOM that set the rules.
Any dispute must be between Sky and OpenReach - Plusnet were not required to do anything and therefore are in no way at fault. Even if the advice given by Plusnet was wrong it doesn't change the rules.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
HPsauce
Seasoned Pro
Fixes: 5
Basically it's messy, but as noted above, first:
Quote from: HPsauce
PN can't assist with that bit at all.
moogaloo
Quote from: jelv
Not sure why you think plusnet are blameless, if this is situatiojn is cause by wrong information given to me by plus net, then it is down to them, if BT Opemnreach are supposed to contact your current ISP when enabling fibre that is more of a grey area.  AS I understnand it ADSL and Fibre can continue to work on the same long, so I am worried that certain wrong assumptions have been made about the role of BT Openreach.
Bright
Your understanding is incorrect (assuming you mean the same line).
jelv
Fixes: 10
Rubbish! If I told you it was OK to drive through a red traffic light do you think the police would be sympathetic if you tried to blame me when you were caught? Being given duff info by a third party doesn't change the facts.
Not at all grey - it's absolutely clear cut. OpenReach physically disconnected your line from the Sky equipment - it is their responsibility to notify Sky. Have you bothered to check the facts with OFCOM?
Wrong again. Your telephone line must be physically disconnected from the ADSL equipment in the exchange before it can be connected to the VDSL equipment in the cabinet.
James
To be clear, we're happy to help by showing proof of when orders were placed and completed, we just can't talk to Sky about this.
moogaloo
No but you can talk to BT Openreach, which is what you originally promised to do.
moogaloo
Quote from: jelv
Plusnet are not a 3rd Party, they where supposed to be the ones arranging everything
HPsauce
Seasoned Pro
Fixes: 5
Quote from: James
That would be helpful to Mogaloo in resolving the outstanding bill from Sky so should surely be done ASAP.
Once that is done the situation between him and PN will then need amicable resolution.  Wink
He appears to have (reasonably) believed:
But you now say (after pointing out that Openreach is actually an intermediary):
Quote from: James
