Oh no not again
- Oh no not again
Oh no not again
18-06-2010 3:34 PM
Bt Speed Test..
Download speed achieved during the test was - 116 Kbps
For your connection, the acceptable range of speeds is 50-250 Kbps.
Additional Information:
Your DSL Connection Rate :160 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 135 Kbps
Whats going on I am getting tired of these line drops,years with no problems now 3 in less than 9 months.Nothing has been touched or changed at my end.
Router specs...Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time
WAN PPPoA 65998 73820 0 648 1718 06:28:42
LAN 10M/100M 60899 0 0 30 0 97:00:37
WLAN 11M/54M 415371 413313 0 637 204 97:00:28
ADSL Link Downstream Upstream
Connection Speed 2112 kbps 448 kbps
comments please.
Re: Oh no not again
18-06-2010 4:00 PM
I would visit http://community.plus.net/blog/2008/02/19/my-broadband-doesnt-work/ ; for connection checks.
And a soon as you sync at a higher rate for 72 hours consistently it will automatically raise. The profile will have lowered due to dropped connections.
Jojo
Re: Oh no not again
18-06-2010 5:23 PM
Dennis
Re: Oh no not again
20-06-2010 4:20 PM
There appears to be far too many speed issues lately.
Re: Oh no not again
20-06-2010 9:11 PM
Re: Oh no not again
21-06-2010 7:08 AM
Re: Oh no not again
21-06-2010 8:40 AM
Re: Oh no not again
21-06-2010 9:29 AM
@denissb66,
Just checked your connection logs and I don't see a 72 hour connection, the best connection you had was:
08:53 18/Jun/2010 14:39 20/Jun/2010 2 Days, 5:46:8
I was wondering if you had noticed your dropped connections since then or had been rebooting your router? If not then I think if you raise a ticket it should be about intermittent connection rather than speed, as that would most likely be the root cause.
@Azagoth,
I've just checked your line @ 9.00 and either you have no sync or your router was off. If you can confirm that your router is on and in sync I can do another line check for you. Otherwise, it may be useful to visit http://community.plus.net/blog/2008/02/19/my-broadband-doesnt-work/ for connection checks.
@ovale,
There are a number of dropped connections on your line, so I have forwarded your ticket to the intermittent faults dept. If there was an interruption on your line during a speed test this would severely affect your results.
Re: Oh no not again
21-06-2010 1:19 PM
Re: Oh no not again
21-06-2010 2:23 PM
the issue would have only caused one dropped connection, which is not enough to lower a profile. There's no definitive amount but rule of thumb would probably say that dropping connection over 3 times in one hour could affect your profile.
Re: Oh no not again
22-06-2010 6:45 AM
Download speed achieved during the test was - 121 Kbps
Re: Oh no not again
22-06-2010 8:31 AM
I've just had another look at things, and the best I can recommend is to leave it with the faults guys, I'm scratching my head on this one too!
Re: Oh no not again
25-06-2010 7:57 PM
WAN PPPoA 331305 456482 0 220 2323 50:45:14
LAN 10M/100M 184199 0 0 36 0 269:14:26
WLAN 11M/54M 1469544 1408563 0 915 249 269:14:17
Connection Speed 2368 kbps 448 kbps
Line Attenuation 57 db 15.5 db
Noise Margin 7 db 19 dbguys.
Router stats above back to normal but not my D/L speed
Download speedachieved during the test was - 120 Kbps
Your DSL Connection Rate :2368 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
120Kbps talk about the dark ages,speeds were faster than this back in 1975 when the ISL4/72 was operational.It took over 2hours just to do an update this afternoon.
