Oh dear PN, router number 7 has just shown its first symptom of locking up.
7up
Fixes: 17
We had a trusty old Mentor router.. old, basic, had to reboot for port adjusting etc but very reliable with no problems with it until our line was renumbered. BT got something wrong, sent an engineer... within a week mentor was dead after over heating a couple of times and loosing the connection.
Then we got through 4 zoom routers. All of which were fine for a month or two and would then over heat, lock up, refuse to do anything, just like the mentor in its final week.
Then came the netgear.. same thing applies..
Then came the Edimax, frequent problems but it managed to survive a whole year before finally going the same way as the others. It will be remembered for it's mighty fight and determination  Cry
Now we're on #7. Yes, you read that correctly, router number 7 (SEVEN, S.E.V.E.N, SeVeN, sEvEn 8-1, 6+1) bought in August for a rather steep £95.. guess what just happened?
It locked up, disconnected the internet and became rather hot just 3 weeks after purchase Roll_eyes A quick reboot turned into 3 minutes before it would sluggishly let me into the admin pages and another 2-3 minutes for it to pick up my external HDD.
Now, I don't know about you Plusnet but I smell a rat with whatever BT done when having the line renumbered and then tinkering with the hardware. Considering BT told us that it was a computerised operation and our BB would be unaffected (even you said it would be ok before it all went dead and you arranged an engineer), why did they then need to send an engineer to tinker with the socket and then go back to the exchange to do more tinkering? - No-one has ever answered this. Clearly, some hardware has been fiddled with and something is wrong with our line.
Router 7 has just started to play up like the rest. I've been on the phone to cisco who assure me this isn't a common issue with the X3000 although they did get me to upgrade the firmware. This still wouldn't explain the other 6 routers, the heat, the only happening since BT got involved thing etc. I had to triple check with the guy who assured me that this is not a normal problem with their routers.
Something is not right with our telephone line and I don't think 5 different router manufacturers (Mentor, Zoom, Netgear, Edimax and now Cisco) can be blamed.
What else do you want from me before you take this seriously?!?!?! PLEASE will someone talk to BT?
31 REPLIES 31
James
Re: Oh dear PN, router number 7 has just shown its first symptom of locking up.
I'm fairly certain that
a) BT aren't frying your routers
b) There are no grounds for us to raise a fault/feedback to them re router flombéing.
c) It is more likely to be internal to your property
If you have a genuine, non-hardware fault, then we can raise this with you through BT, provided you fill in the standard fault form (preferably calmly) @ http://faults.plus.net
orbrey
If it's an overheating issue I'd be almost certain it's power related rather than phone line. I know there is power sent down the phone line but I'd be very surprised if it was that rather than possible surges on a 240v supply. Just a thought though.
James
Do you have a surge protector?
Given the repeat issues you have had it would make sense to try one.
A renumber is a robotic activity and *CANNOT* cause the problems you are describing.
w23
Fixes: 4
Each router would have its own PSU, some better quality than others, most provide full mains isolation and reasonable voltage regulation, I would expect mains issues to fry a PSU and not a router.  @ Sprite, has any other household equipment 'fried' during this time?
I would not dismiss the possibility of externally induced interference or 'spikes' on the phone line in addition to the possibility (however remote) of faulty exchange equipment, neither should you dismiss the possibility of other equipment or internal wiring causing a problem (unless you have absolutely no other wiring connected to the master socket).
For what little difference it might make I always keep my router plugged into a decent surge protected socket strip.
Call me 'w23'
7up
Fixes: 17
Quote from: Jameseh
So how do you explain this keep happening since BT tinkered with the hardware? - No seriously, a logical explanation would be great, then perhaps we can work around it because I can't see anything else being at fault here. Before the line was renumbered, we had no problems. Sure, sometimes you'd disconnect us in the night but it would reconnect when it could and we'd have months of usage with the old router. Sure, I've never been happy about the bandwidth throttling on P2P and I've been vocal about that many times along with a few other glitches but the router was reliable until BT got involved.
I would like am explanation as to how that has changed since their man came here and then rang me from the exchange saying he'd fixed 'it'. What was 'it' ? You and BT told us the line renumber would have no serious effect yet for some reason they had to fix 'it' and we've been through 7 routers since then.
Quote from: Jameseh
Roll_eyes You know something, I've had it with this attitude. I have just told you about it, 5 different brands of router, 7 different routers in total, the time of it starting since BT got involved and you still doubt that this is genuine?
Quote from: Jameseh
(preferably calmly)
I am calm. I just have better things to be doing than trying to sort out something not caused by me. It's true I've had a very stressful life in the past and some of your company antics have pushed me over the edge but I am currently 'calm' and 'genuinely' trying to get this resolved. All I have done above is underline and bolden a few things to ensure its taken note of. You're asking me to be genuine?
Roll_eyes
Quote from: Matt
It's plugged into a surge protector (power not phone line) so I've got no idea what else to do.
Quote from: Jameseh
Yes and yes the router is plugged into it (mains only not the phone line as I don't have any wires for that though the surge protector has the sockets).
Quote from: Jameseh
So given that its robotic, there is the ability for the robot to screw something up - eg a servo malfunction, gearbox failure inside a servo, controller failure.. Robots although highly reliable do have faults and do go wrong. They are mechanical machines just like cars. Cars go wrong. Thats why we have breakdown services. Mechanical things go wrong - ever heard the saying "Spanner in the works" ?
I'm not actually sure if you meant robotic or electronic / compuertised. If you did, it only serves to show that even you guys at PN can get things wrong and thats why you shouldn't be so quick to dismiss this.
I don't care what you say James, the fact is BT sent an engineer around previously (thanks to your help) and then he rang me from the exchange a while later saying he'd fixed 'it' and could hear our modem resync'ing.
Quote from: w23
No, just the routers. Strangely, the original voyager 105 usb modem that PN sent us can operate for months at a time with no issues though I can't use that for Win7 as support for usb modems was withdrawn apparently (yet dongles were invented just in time for... Win7!)
Quote from: w23
You wouldn't but PN have Sad I can't believe that you as another user of PN can see this possibility yet a communications company can't get the grasp of this basic idea.
Quote from: w23
My PC setup changes every few months with wires being removed, others added etc. At the time this started I never had a surge protector OR a UPS (with another surge protector built in). There have also been physical PCs switched around, upgraded, retired etc yet the router problem persists.
James
Robotic activity is a BT term - meaning it's just a data change (or variable if you like).  It can't cause additional power to surge down your phone line.
I'm not an electrician so I'm not going to attempt to explain why your routers are dying. But I'm also not going to raise a fault to BT about this because I know exactly what would(n't) happen and it would be a waste of our collective time.
I'm sorry if you don't like my attitude, but I'm giving you a realistic explanation which you have taken issue to.
I've nothing further to say in this thread.
7up
Fixes: 17
Quote from: Jameseh
So why did BT have to fiddle with the hardware at all? Why did YOU James personally arrange for an engineer to look at it? Why did he then fix 'it' ?
A simple renumber being a robotic operation that can't break anything did just that - it BROKE SOMETHING. You're now telling me that this can't happen?
Quote from: Jameseh
Yet a couple of years back BT dug up some cables down our road saying the water down there had caused some electrical problems..
Quote from: Jameseh
Note sure if you mean you know what wouldn't happen electrically or with BTs investigations. Either way, I've brought this fault to you and you're saying you won't help because you know better - despite just having to explain how robotic actually means something else.
Quote from: Jameseh
I've taken no issue to what you've said. I've just asked for help and tried hard to get you to see this from my POV - the person who is suffering with it. You are not trying to help me at all.
ReedRichards
Seasoned Pro
Fixes: 25
w23
Fixes: 4
Quote from: Sprite
Coincidence? (It does happen).
Most important, surely, is not to necessarily blame something that happened I don't know how long ago but to try to find out what the current problem is with a view to getting it fixed.
Is there any extension wiring to the master socket, can you use the test socket and leave it there to rule out all internal (extension) wiring and other connected equipment?
To add to ReedRichards' suggestion: http://www.ispreview.co.uk/talk/showthread.php/27624-Using-Surge-Protectors-on-ADSL-lines
Call me 'w23'
7up
Fixes: 17
Quote from: ReedRichards
Help?
http://www.amazon.co.uk/Broadband-Modem-Router-Surge-Protector/dp/B002SOZ6BE/ref=pd_sim_sbs_ce_4
Rich you legend, that might just save me. If only plusnet were so helpful! I never knew surge protectors existed in that form.
Quote from: w23
According to James it doesn't! (Despite him personally arranging a BT engineer when the line renumber went badly wrong!). BT just change a variable with the use of a robot! I've no idea how this happens, I assume it must be precision programmed to cut out blocks of transisters and then resolder them to others to change the state of the memory?  Cheesy
Quote from: w23
You're missing the point. This has been going on for a couple of years ever since BT came out. PN refuse to believe it or that something might be wrong with the line. If I started a new thread saying I think our line is frying our router, no-one would believe it. That is why I've had to mention the BT fix and the previous 6 routers that have all gone the same way - because it adds support to my side of the arguement. I'm not trying to blame BT, PN or even make a claim for the loss of the routers I simply want it to stop happening.
Quote from: w23
No extension. Well, technically there is one but we've never used it and its not plugged in - It's one of those DIY things that someone tacked in up the stairs and under the carpet etc. We've never tried to use it as we use cordless phones and the plug is still hanging off the skirting board onto the floor under the socket. All we have connected to the master socket is the DSL filter, a cordless phone and the router.
w23
Fixes: 4
The surge protector thing certainly looks worth a punt at that price!
If you give it a go then I'd take a note of your Attenuation, sync speed and SNR margin before installing it then check again after just to make sure it doesn't have any bad effects (particularly any significant increase in the attenuation figure).
Now I just need to find out is any of these devices are compatible with VDSL2 (FTTC).
Call me 'w23'
avatastic
Do you have any haired pets? Fur is a good insulator and if its getting into all your routers that could explain the overheating.
F9 member since 4 Sep 1999
F9 ADSL customer since 27 Aug 2004
DLM manages your line the same way DRM manages your rights.
Look at all the pretty graphs! (now with uptime logging!)
Griffsters
Have you checked for any leaves on your line?
Sorry, couldnt resist
CX
Could it be that the issue is coming from the LAN/ethernet side?
Several years ago we troubleshooted a problem related to a cable modem and somebody's TV card. If they connected ethernet from their PC containing the satellite card to their cable router, the lost connectivity. Disconnect the TV feed from the PC, and it was fine. Disconnect the incoming cable internet and the router behaved. I don't recall the specifics now, but I remember it being caused by leakage from another receiver or TV in the house (the whole lot was connected to TV distribution system).
Have you checked absolutely everything on the LAN side? How much gear do you have connected to it?
And are the routers actually dying? A misbehaving piece of equipment on your LAN can take down a switch by bombarding it with packets (well, garbage). I encountered this with a failing NIC on an old motherboard - after some time I would lose a section of my network, and it was the section with this PC connected to it. Disconnect that and it all returned to normal. It got progressively worse and worse over time. My point is this - have you ever taken the "broken" routers to another premises to see whether they are still "broken" there?
I'm not doubting you, so please don't take this as an insult, but it's worth exploring every possibility.
