Offpeak usage limit for Legacy product (Broadband Premier Option 1/2/3)
- Offpeak usage limit for Legacy product (Broadband ...
26-11-2007 4:23 PM
Hi ya,
I cannot seem to find the conditions for offpeak usage limit for legacy product (Broadband Premier)
Is it unlimited like BBYW?
Message 1 of 5
(1,191 Views)
4 REPLIES 4
Re: Offpeak usage limit for Legacy product (Broadband Premier Option 1/2/3)
26-11-2007 4:27 PM
Hi Guli,
There are no set limits for the amount that you are entitled to download off peak.
Message 2 of 5
(475 Views)
26-11-2007 4:29 PM
Thanks, James for such quick reply.
I cannot seem to find that in writing though. I did kind of remember that Premier used to have some off-peak guidelines (100GB/Option1, 150GB/Option3) etc, but I might be wrong.
Thanks again
Thanks again
Message 3 of 5
(475 Views)
26-11-2007 5:13 PM
Are the off peak usage guidelines still enforced for these products?
Message 4 of 5
(475 Views)
26-11-2007 5:25 PM
The only way we'll need to take measures (ie basically ask people who are using a great deal of bandwidth off peak to slow down a bit) is if our network begins to suffer as a result. Given that things are fine as they stand and we're adding capacity in line with the expansion of the network, there are no signs that this will come to pass in the future either.
So basically, go for it.
Hope that helps,
Hope that helps,
Message 5 of 5
(475 Views)
