Off Peak Connection Problem
- Off Peak Connection Problem
26-09-2007 4:19 PM
Firstly appologies if this has already been posted, if so maybe someone could point me in that posts direction.
Anyway the problem I have is that my pc's connection to broadband always gets disconnected during the off peak hours.
I can't recall loosing my connection once during the day, however after midnight I am always loosing my connection. I reconect, but after a while I will loose my connection again. This is annoing, as I am trying to do any large downloading during these hours, but it is proving very hard.
All I have to do is turn my router on and off, and I have my connection back, but it never stays. However I don't have this problem during the day?
Can anyone help me out at all?
Message 1 of 2
(1,268 Views)
1 REPLY 1
Re: Off Peak Connection Problem
26-09-2007 4:21 PM
There are a few things that I would suggest that you try first:
- Try changing your filters
- Ensure that you are connecting into your master socket via a filter
- Try a different modem if possible
- Try connecting your filter into the test socket behind your master faceplate if possible
If the problem continues, then please raise a fault via http://faults.plus.net
Message 2 of 2
(289 Views)
