Odd
Mask
Odd
I occasionally get this on a page.
I don't enter my log in info, I never trust random pop ups, although it's not strictly a pop up, it's on a tab that is trying to load a page. I usually close the tab, and other tabs work ok.
I'm wondering is this something to do with my connection. But I also want to double check it's not some phishing thing that's in my laptop.
This isn't a major issue, it's quite rare, I've probably only had it about 3 or 4 times. I'm just curious.
I use a MacBook Pro if that's significant.
Re: Odd
That's the router's admin page, it's perfectly fine - though you're seeing it because the router isn't connected at the time which is why you get that page instead of the page you've tried to visit.
From checking your router logs there aren't many disconnections that we can see:
<img src="http://community.plus.net/visualradius/generated/image13820236096029.png"/>
If there's more than that then it'd definitely be worth raising a fault at http://faults.plus.net - once you've answered the questions there it'll drop a ticket to our faults team who'll get this sorted for you.
Mask
Re: Odd
Ok, thanks, I'll monitor it. As I said, it's not very often, and hasn't caused too much of an issue at this point.
