Odd routing
- Odd routing
Odd routing
02-07-2009 4:20 PM
Although I am a Plusnet customer, I have an interesting issue with my work BT Internet connections and Plusnet infrastructure.
A tracert www.bbc.co.uk and a tracert bbc.co.uk yield different paths with one of them failing at hop 6. I noticed that within the hops is Plusnet, hence this post.
Is BT Internet using Plusnet infrastructure exclusively now?
I also understand from a friend that although they are BT customers they have had to change MTU setting due to the Plusnet routing.
Any ideas?
Cheers,
Richard
Any ideas?
Cheers,
Richard
Message 1 of 5
(971 Views)
4 REPLIES 4
Re: Odd routing
02-07-2009 4:22 PM
Hi Richard,
I've not heard of anything like that before. Unless it's part of the Broadband Scope platform?
Mind posting a traceroute?
Message 2 of 5
(432 Views)
Re: Odd routing
02-07-2009 4:34 PM
Hello James,
Results below:
bbc.co.uk
1 <1 ms <1 ms <1 ms 192.168.0.1
2 20 ms 14 ms 16 ms lo0-plusnet.pte-ag2.plus.net
3 32 ms 14 ms 14 ms ge0-0-0-504.pte-gw2.plus.net
4 18 ms 21 ms 15 ms vl23.thn-gw2.plus.net
5 208 ms 224 ms 207 ms rt0.thdo.bbc.co.uk
6 14 ms 17 ms 16 ms 212.58.238.133
7 15 ms 18 ms 15 ms rdirslb0.thdo.bbc.co.uk
8 20 ms 16 ms 20 ms virtual3.rbsov.bbc.co.uk
www.bbc.co.uk
2 18 ms 16 ms 29 ms lo0-plusnet.pte-ag2.plus.net
3 15 ms 29 ms 17 ms ge0-0-0-504.pte-gw2.plus.net
4 103 ms 220 ms 236 ms vl23.thn-gw2.plus.net
5 15 ms 14 ms 14 ms rt0.thdo.bbc.co.uk
6 26 ms 18 ms 16 ms 212.58.238.133
7 14 ms 15 ms 15 ms 212.58.239.58
8 * * * Request timed out.
Thanks,
Richard
Results below:
bbc.co.uk
www.bbc.co.uk
Thanks,
Richard
Message 3 of 5
(432 Views)
Re: Odd routing
02-07-2009 7:41 PM
It's the bbc, www.bbc.co.uk doesn't respond to ping but bbc.co.uk does.
Message 4 of 5
(432 Views)
Re: Odd routing
02-07-2009 8:16 PM
Richard, are those traceroutes from your BT work connection? If so, James' assumption is very likely to be correct and your work connection is probably being supplied through this.
Message 5 of 5
(432 Views)
