Odd Speedtest readings (0 upload) and occasional slow internet
- Odd Speedtest readings (0 upload) and occasional s...
Re: Odd Speedtest readings (0 upload) and occasional slow internet
13-08-2017 1:48 PM
OK, dragged the old TG582n out of attic and have routerstats running. Let me know what info you want.
Jon
13-08-2017 2:09 PM
The 'old' TG582n - especially on the last firmware update is a good option for hanging into the dsl connection. It's the model I still use and I see dsl and ppp session lasting months.
However I think you have found enough evidence to raise an intermittent noise fault with your phone supplier. Least they can do is a full CLT for you.
13-08-2017 2:24 PM
13-08-2017 2:30 PM
Can you attach graphs please - those logs are not easy to read / analyse. You can raise a phone fault on line through the user portal.
13-08-2017 3:03 PM - edited 13-08-2017 3:04 PM
Sorry, this any better. Probably going back to the TP-LINk as it seemed to hold a connection better. Bit worried now as it seems to be getting worse and have a lot of stuff to do tomorrow!
13-08-2017 3:22 PM
That's enough evidence for me to suggest you have a fault (or possibly REIN) somewhere. You need to be getting a fault report raised.
Unless you have some suspicion that the TG582n is faulty I would leave it in place running at the higher SNRM/ slower speed so that you can see better stability and be able to see what is happening to the SNRM with less chance of the line dropping.
If you keep poking this with a stick you are not going to be able to see clearly where the snake is. That graph is most helpful ... it suggests that the target has been moved to 15dB on the last resynch and that at the time of the resynch there was still some noise present which has since faded away.
13-08-2017 3:59 PM - edited 13-08-2017 4:13 PM
Pretty much unusable now - see attached.
Going to try the TP-Link for a bit.
Where on earth do I raise a ticket. I can never find the page in PN's convoluted system which seems designed to avoid you raising one! [Edit: ignore - got to it through BB fault checker. Phone line checker got me nowhere]
The phone checker reports no problem. Chat has a backlog and I can't wait an hour on the phone!
Jon
13-08-2017 4:24 PM
Is this dropping of its own accord or are you rebooting the router? If the latter please don't do that.
@Gandalf,
What's the target SNRM on this line please? Is there merit in doing a temporary elevation to 9 or 12dB to deliver stability whilst the root cause is investigated and resolved please?
13-08-2017 4:36 PM
Dropping of its own accord. I have only rebooted once other than the other couple of times when switching routers. But they are not on the graphs I just posted.
Jon
13-08-2017 4:43 PM - edited 13-08-2017 4:44 PM
Profile Info: | WBC 160K - 24M No delay (INP 0) 6dB Downstream, UC No delay (INP 0) 6dB Upstream (ADSL2+) |
Moving the SNR target upwards would just be masking the problem. At this stage, I'd recommend an engineer visit
I'll take a look at your fault ticket now and I'll send you an e-mail shortly.
13-08-2017 4:46 PM
Oh that's worrying - given some of those plots showed an SNRM well above 6d,B that rather implies a significant level of line noise being present at the time of the resynch.
14-08-2017 9:00 AM
Have responded to request for engineer visit. Hopefully it will be soon.
Has stayed connected since 7.30pm last night:
Upstream | Downstream | |
Current Rate (Kbps) | 423 | 12563 |
Max Rate (Kbps) | 496 | 16336 |
SNR Margin (dB) | 12.3 | 12.1 |
Line Attenuation (dB) | 18.5 | 30.5 |
Errors (Pkts) | 0 | 0 |
14-08-2017 9:12 AM
Good morning Jon - I note that SNRM is 12dB - I recommend avoiding rebooting the router if you can so that you have some chance of getting all you need to do today done.
You show real professionalism and care ... many support agents would have jumped at raising the SNRM as an end fix for this issue. I only suggested it as a temporary fix so that Jon could get all he needs to do today done ... whilst BTOR get around to getting feet on the ground ... and maybe not finding the cause of the issue.
14-08-2017 9:14 AM
Thanks both, am beavering away whilst I have a connection and will not reboot.
Jon
14-08-2017 10:14 AM
Just had call from PN. Engineer booked tomorrow morning. Excellent service from PN.
