Occasional dropouts, can you check my stats??
- Re: Occasional dropouts, can you check my stats??
13-06-2012 9:22 AM
I have a broadband router which on occasions drops off completely. The Loop AStt is 52 and the SNR Margin hovvers from about 4 to 8... I'm suspecting this drops when i get disconnected...... do these stats show line issues?
Message 1 of 4
(872 Views)
3 REPLIES 3
13-06-2012 10:28 AM
Doesn't look like it's dropping that often:
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13395796529063.png" />
Have you seen the connection dropping more often than that?
Message 2 of 4
(419 Views)
13-06-2012 11:08 AM
cheers matt - not my router - asking on behalf of friend.....
Message 3 of 4
(419 Views)
13-06-2012 11:24 AM
Ah, apologies
In which case, that's a fairly high attenuation and I'm not surprised it drops with an SNR around 3 or 6. 9 should be more stable though and I believe that's what it'll be set to when he records a figure of 8.
Not sure what service he's on but he could try asking his ISP to set the SNR to 9 or 12dB, that might help things. Otherwise he'd just have to report a dropping connection fault and see what happened there.
Hope that's a bit more helpful...
Message 4 of 4
(419 Views)
