Occasional BBC iPlayer buffering
OnFire
Not sure why, but I am getting occasional buffering when using BBC iPlayer, and just wondering if other Plusnet users are also experiencing this. Is it congestion?
http://www.bbc.co.uk/iplayer/diagnostics
The BBC diagnostics test shows I have more than adequate speed, so not sure why the buffering. Is it annoying!
Thanks for any help.
Re: Occasional BBC iPlayer buffering
Are you running wired or wireless? Is it happening all the time of specific times of day?
OnFire
Sorry, should have explained that it is a wireless device, so this could be a WiFi congestion issue, also it does only seem to happen in the evening - so peak time.
Thanks.
Plusnet Staff
Plusnet Staff
Fixes: 5
Do you still get the same problems when connected via Ethernet?
Chris Pettitt
Cloud Environments Engineer
