OR modem wan port speed?
- Re: OR modem wan port speed?
05-06-2013 5:01 PM
Just bought a nice new router that supports 1000mb and on the wan port.
Also while I'm already asking, whats the max speed for a FTTC connections?
05-06-2013 6:00 PM
Max speed currently is <80Mb but they are looking at 120Mb soon.
05-06-2013 6:31 PM
05-06-2013 6:57 PM
05-06-2013 7:36 PM
I was under the impression it was only 100Mbps
See
http://forum.kitz.co.uk/index.php/topic,11818.msg237439.html#msg237439
First post - No 210
Modem on profile 30a (up to 200Mbps) can only support 100Mbps max - 'cos that is its max even though it will sync OK on profile 30a
05-06-2013 9:12 PM
05-06-2013 11:51 PM
Quote from: Blim
Just being nosey here.... What router did you get? (I'm thinking about an upgrade at the moment)
06-06-2013 12:54 AM
06-06-2013 11:25 PM
10-06-2013 3:58 PM
The things this router can do.....
You can download torrents with just the router, host the files on a ftp server also on the router. You can then setup a media center or a cloud server and stream your downloads to your mobile, tablet, laptop or anything that is connected to the internet or your home network. All with just the router connected to my connection ofc.
So many more things this router can do but thats just amazing dont you think?
10-06-2013 4:12 PM
Have a look here - http://www.ispreview.co.uk/index.php/2013/04/bt-confirm-first-uk-trial-areas-for-superfast-broadband...
That maybe what you were asking about?]
