OOOps
rongtw
Fixes: 12
OOOps
i just gateway hopped  Wink
and got this  Huh
Fixes: 62
Re: OOOps
That is interesting
This is from looking up your IP address
netname:        PARBIN-NET-G
descr:          Parbin Limited
descr:          ADSL Connections
country:        GB
<snip>
role:            Parbin Hostmaster
address:        PlusNet Plc
address:        The Balance
address:        2 Pinfold Stree
Re: OOOps
The company was dissolved on 31/08/2012 according to Companies House.
I think PN need to update the RIPE registry on this one.
Fixes: 77
Re: OOOps
Hi all,
I'm flagging this with a network engineer now.
It let you know if we're able to share what the reason for this was.
UPDATE:
issue mentioned is because the new VR (Central12 on pcl-bng02) isn't in the gateway checker and neither are the Parbin addresses so there's no issues with IP registry.
Sorry if this is an inconvenience for anyone but we're unable to prioritise getting those added to the checker at present.
 Adam Walker
pwatson
Re: OOOps
Quote from: AndyH
PN took them over in 2005!
Fixes: 22
Re: OOOps
You can use the debug mode: http://usertools.plus.net/@gateway_custom?debug-ip
Or just open a command prompt and run tracert - the plusnet gateway is the first hop after your router.
Clearly we're scraping the bottom of the IPv4 address barrel these days.
Re: OOOps
@ Adam - Surely Plusnet should update the RIPE database to change Parbin Limited to Plusnet plc?
@ pwatson - yep, but Plusnet shouldn't be using the company name anymore because it has been dissolved.
rongtw
Fixes: 12
Re: OOOps
I just did the link from EJS  it looks weird
Fixes: 21
Re: OOOps
You may want to delete your precise IP address from that image.
That's a standard looking output for the debug. The following from a whois
% Information related to '213.162.100.0 - 213.162.100.255'
% Abuse contact for '213.162.100.0 - 213.162.100.255' is 'abuse@plus.net'
inetnum:        213.162.100.0 - 213.162.100.255
country:        GB
admin-c:        PH1124-RIPE
tech-c:         PH1124-RIPE
status:         ASSIGNED PA
mnt-by:         PARBIN-MNT
source:         RIPE # Filtered
address:        2 Pinfold Street
address:        Sheffield
address:        S1 2GU
phone:          +44 114 2200084
remarks:        trouble:  Please report any network abuse to abuse@plus.net
admin-c:        SB195-RIPE
tech-c:         RM6084-RIPE
nic-hdl:        PH1124-RIPE
mnt-by:         PARBIN-MNT
abuse-mailbox:  abuse@plus.net
% Information related to '213.162.96.0/20AS6871'
route:          213.162.96.0/20
descr:          PARBIN-213-162-96-0-20
origin:         AS6871
mnt-by:         MAINT-AS6871
mnt-routes:     MAINT-AS6871
mnt-lower:      MAINT-AS6871
% This query was served by the RIPE Database Query Service version 1.74.1 (DB-1)
which is presumably what Jim looked at.
rongtw
Fixes: 12
Re: OOOps
Yes i hopped gateway again to clear it Smiley
Fixes: 21
Re: OOOps
That's quicker than editing the image  Grin
