OOOOOOOOOps
rongtw
Fixes: 12
OOOOOOOOOps
well i dunno where to start  Undecided  but after loads of posts and a visit from a BT engineer  Wink  I still get This
Fixes: 341
Re: OOOOOOOOOps
that's not bad is it?
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
rongtw
Fixes: 12
Re: OOOOOOOOOps
for the amount of errors  Shocked  i suppose not .
but i still get horrendous gaming on a evening  Cry
Re: OOOOOOOOOps
Hi, horrendous in what way?
Fixes: 62
Re: OOOOOOOOOps
Given the fact that the line is interleaved - not too good for gaming - there are far too many uncorrected errors which could well kill gaming response
It may well be worth asking if the default noise margins (up and down) can be raised
As a comparison these are my stats after 5 days and I have a noisy line
Noise Margin:     4.1   dB
Connection Rate:  4928  Kbps
Line Attenuation: 50.0  dB
Power:            19.6  dBm
Max Rate:         5216  Kbps
SuperFrames:      26,055,933
SF (CRC) Errors:  7,584
Reed Solomon:     1,771,803,474
RS Corrected:     1,437,337
RS Un-Corrected:  87,811
HEC:              6,204
rongtw
Fixes: 12
Re: OOOOOOOOOps
lagg  Embarrassed high pings, constant disconnections from servers,
PN has done everything in their power but its a pain in the bum for 10% of  the time , the other 90% its brilliant , but all i see is the High errors nowt else points to any problem , unless like the BT man said i Get  " rain "  somewhere on my line someone causes interference  Sad
Re: OOOOOOOOOps
He probably meant REIN. Have a read and see if it rings any bells...
rongtw
Fixes: 12
Re: OOOOOOOOOps
Yup that's it Jaggies  Wink   my bad  exactly what he said , as it mostly happens evenings 20.00-2200  Undecided
you can play fine then all of a sudden its like Michal Jackson Moonwalk everything just slows down.
Re: OOOOOOOOOps
Hi rongtw,
about a year ago I suspected a REIN issue, one specific 'feature' I had was CRC errors clocking up at a steady high rate when is was happening, see this routerstats graph: http://community.plus.net/forum/index.php?action=dlattach;topic=94027.0;attach=22605;image can you log similarly using Routerstats?
Incidentally, my issue was never really solved - my 'solution' was to reboot the router when things were bad which gave a significantly lower sync but dropped the errors to a much lower level and made the connection useable (even for casual gaming), I also mamanged to get my line profile 'fixed' (no normal DLM action), can't find the thread at the moment but it was a Plusnet trial so I kept fastpath despite the issues.
I have since moved to Fibre and not seen any of the previous problems since so never really followed it to final conclusion.
Call me 'w23'
Re: OOOOOOOOOps
Quote:
"as it mostly happens evenings 20.00-2200"
This is peak time, are you sure yoru gaming traffic is classed correctly by PlusNet? What package/connection type are you on?
3Mb FTTC
rongtw
Fixes: 12
Re: OOOOOOOOOps
yes game is classed correctly BF3 . and am on PN extra adsl+2
and walker23 hopefully this month i should be able to get FTTC  Cool
