OK James, I give in - change me over . . .
- OK James, I give in - change me over . . .
24-10-2007 2:30 PM
http://community.plus.net/forum/index.php/topic,2035.60.html
Quote from: Original Do we have an answer to . .
So, if I decide to change from my Metronet 1mb IPstream connection including 2Gb usage for £13.75 p/m, to the Plusnet Option 1 with 3Gb for £11.49 . . . . . would I still get the loyalty discount I have already been offered?
Quote from: Mand Oh go on then.
Seriously, if we've made an offer of a discount to you and you take it, this will still stand even if you change product, including a Metronet to PlusNet product. You would not be able to claim deferred hardware as well though.
. . . I have decided to take the plunge, direct debit and all. *resigned sigh*.
So, as I understand it I need to sign up for a PN dial up account set up the DD and then raise a ticket so James (or whoever draws the short straw) can do the 'bodging' required to get me switched over to PN. [Keeping in mind all the while that I don't want to be 'maxed' ;)]
Question 1) My billing date is the 25th, ie tomorow, presumably when I know the amount I should raise a cheque as usual for MN.
As PN is paid in advance, could I send a cheque for that at the same time, as I seem to remember there can be a delay in setting up the DD.
Question 2) Can I keep my existing user name? There are no email complications as my mail is hosted elsewhere, and I would just need to change the SMTP address for my outgoing mail.
Regards - Alastair
Re: OK James, I give in - change me over . . .
24-10-2007 2:35 PM
I think the best bet is to send in your cheque as normal and then set up your direct debit on your new account and I'll arrange for your change over to happen on the billing date afterwards, to avoid potential confusion.
Yes, all you would need to do would be to sign up for a PN Dialup account and set up a Direct Debit, which takes 5 working days. then raise me a ticket and I'll ensure that all of the neccesary work is done.
You may be able to keep your existing username, if it is available on PlusNet.
24-10-2007 2:39 PM
Alastair
01-11-2007 12:31 PM
Thanks - Alastair
01-11-2007 12:48 PM
I've replied to your ticket.
01-11-2007 1:03 PM
That's the one!
A
13-11-2007 9:26 AM
Also, do I need to formally sign up for the loyalty discount or is that included in your 'things to be bodged, list?
Thanks - Alastair
13-11-2007 9:28 AM
That's a good point. The order won't complete until the Monday. I'm doing it in a way that it won't just break. You'll be able to log into the Plusnet account on the Monday
We can sort out your loyalty discount once everything else has gone through.
13-11-2007 10:23 AM
A
03-12-2007 11:08 AM
The regrade to max has gone through this morning with the router connection rate showing 7616kbps down/448kbps up, and the BT speedtester shows a line profile of 6500kbps with an actual throughhput of 5662kbps, so your prediction was remarkably accurate.
I will monitor the stability over the next couple of weeks.
Can you also sign me up for the loyalty discount, or do I need to raise a ticket?
Thanks again for maintaining the great tradition of Metronet customer service, I hope your bosses realise what an asset you are . . .
Regards - Alastair
03-12-2007 11:16 AM
If you could go to this link:
http://www.plus.net/wizard/index.html?action=wizard&wizard_id=42&WT.mc_id=ec_int200709ocac__pn&link=...
It'll allow you to apply for the loyalty offer, which should get actioned within 24 hours or so (it's an automated thing).
Glad that the Max upgrade went as well as I thought it would.
