O2's Tu Go service No call volume on incoming or outgoing calls
- O2's Tu Go service No call volume on incoming or o...
- « Previous
- Next »
Re: O2's Tu Go service No call volume on incoming or outgoing calls
24-04-2014 11:25 AM
Quote from: AndyH It could be the Openreach modem
Taking a step back, the OpenReach modem has been the only consistent item in the many many tests that I have done. Perhaps it is indeed faulty.
24-04-2014 1:00 PM
24-04-2014 5:31 PM
Here are the trace routes as requested;
Quote Traceroute has started…
traceroute to www.amazon.com (176.32.98.166), 64 hops max, 72 byte packets
1 10.0.1.1 (10.0.1.1) 4.426 ms 4.092 ms 3.771 ms
2 lo0-central10.pcl-ag02.plus.net (195.166.128.183) 178.411 ms 187.606 ms 21.953 ms
3 link-a-central10.pcl-gw01.plus.net (212.159.2.164) 21.488 ms 22.244 ms 20.672 ms
4 xe-10-1-0.pcl-cr01.plus.net (212.159.0.196) 143.300 ms 157.692 ms 27.385 ms
5 xe-11-2-0.edge3.london2.level3.net (212.187.201.213) 160.736 ms 21.005 ms 23.555 ms
6 vl-3201-ve-128.ebr2.london2.level3.net (4.69.202.177) 329.422 ms 186.417 ms 187.032 ms
7 ae-41-41.ebr1.paris1.level3.net (4.69.159.82) 187.184 ms 188.554 ms 187.649 ms
8 ae-71-71.csw2.paris1.level3.net (4.69.161.82) 187.673 ms 188.562 ms 186.128 ms
9 ae-72-72.ebr2.paris1.level3.net (4.69.161.97) 187.355 ms 185.723 ms 186.680 ms
10 ae-41-41.ebr2.washington1.level3.net (4.69.137.50) 186.362 ms 186.028 ms 186.909 ms
11 ae-72-72.csw2.washington1.level3.net (4.69.134.150) 188.533 ms 157.718 ms 186.784 ms
12 ae-2-70.edge3.washington1.level3.net (4.69.149.81) 187.062 ms 187.534 ms 186.622 ms
13 * * *
14 * * *
15 * * *
traceroute to www.amazon.co.uk (178.236.6.251), 64 hops max, 72 byte packets
1 10.0.1.1 (10.0.1.1) 8.084 ms 4.510 ms 4.152 ms
2 lo0-central10.pcl-ag02.plus.net (195.166.128.183) 23.478 ms 22.641 ms 22.260 ms
3 link-b-central10.pcl-gw02.plus.net (212.159.2.166) 21.551 ms 23.361 ms 21.346 ms
4 xe-10-1-0.pcl-cr02.plus.net (212.159.0.198) 24.670 ms 24.055 ms 21.712 ms
5 ae1.ptw-cr02.plus.net (195.166.129.2) 21.493 ms 22.380 ms 25.565 ms
6 195.66.237.175 (195.66.237.175) 22.132 ms 22.705 ms 22.043 ms
7 178.236.3.57 (178.236.3.57) 31.516 ms 32.303 ms 32.247 ms
8 176.32.106.29 (176.32.106.29) 34.147 ms 32.519 ms 34.317 ms
9 178.236.0.181 (178.236.0.181) 33.005 ms 32.036 ms 36.711 ms
10 178.236.0.213 (178.236.0.213) 34.330 ms 40.200 ms 32.887 ms
11 178.236.14.108 (178.236.14.108) 34.141 ms 34.279 ms 35.210 ms
12 178.236.14.114 (178.236.14.114) 33.845 ms 32.504 ms 33.586 ms
13 178.236.6.251 (178.236.6.251) 31.424 ms 31.688 ms 31.157 ms
traceroute: Warning: www.bbc.co.uk has multiple addresses; using 212.58.246.92
traceroute to www.bbc.net.uk (212.58.246.92), 64 hops max, 72 byte packets
1 10.0.1.1 (10.0.1.1) 4.327 ms 3.977 ms 4.610 ms
2 lo0-central10.pcl-ag02.plus.net (195.166.128.183) 21.824 ms 21.944 ms 24.877 ms
3 link-a-central10.pcl-gw01.plus.net (212.159.2.164) 22.041 ms 21.404 ms 24.522 ms
4 xe-10-1-0.pcl-cr01.plus.net (212.159.0.196) 21.625 ms 21.319 ms 25.042 ms
5 ae1.ptw-cr01.plus.net (195.166.129.0) 22.204 ms 21.326 ms 21.363 ms
6 kingston-gw.thdo.bbc.co.uk (212.58.239.6) 21.794 ms 23.804 ms 22.061 ms
7 * * *
8 ae0.er01.cwwtf.bbc.co.uk (132.185.254.93) 22.159 ms 22.478 ms 22.557 ms
9 132.185.255.165 (132.185.255.165) 23.610 ms 24.320 ms 23.424 ms
10 bbc-vip013.cwwtf.bbc.co.uk (212.58.246.92) 22.628 ms 22.359 ms 22.359 ms
traceroute: Warning: www.bbc.com has multiple addresses; using 212.58.246.95
traceroute to www-bbc-com.bbc.net.uk (212.58.246.95), 64 hops max, 72 byte packets
1 10.0.1.1 (10.0.1.1) 4.436 ms 7.050 ms 3.850 ms
2 lo0-central10.pcl-ag02.plus.net (195.166.128.183) 23.298 ms 21.770 ms 21.713 ms
3 link-b-central10.pcl-gw02.plus.net (212.159.2.166) 21.592 ms 21.711 ms 21.602 ms
4 xe-10-1-0.pcl-cr02.plus.net (212.159.0.198) 23.288 ms 22.461 ms 26.123 ms
5 ae1.ptw-cr02.plus.net (195.166.129.2) 35.521 ms 22.345 ms 37.283 ms
6 ae2.ptw-cr01.plus.net (195.166.129.4) 21.576 ms 21.967 ms 21.279 ms
7 kingston-gw.thdo.bbc.co.uk (212.58.239.6) 21.711 ms 22.908 ms 21.629 ms
8 * * *
9 ae0.er01.cwwtf.bbc.co.uk (132.185.254.93) 161.883 ms 23.006 ms 165.374 ms
10 132.185.255.165 (132.185.255.165) 24.216 ms 164.926 ms 23.320 ms
11 bbc-vip016.cwwtf.bbc.co.uk (212.58.246.95) 22.499 ms 160.795 ms 23.304 ms
traceroute to star.c10r.facebook.com (31.13.64.81), 64 hops max, 72 byte packets
1 10.0.1.1 (10.0.1.1) 4.498 ms 3.785 ms 3.770 ms
2 lo0-central10.pcl-ag02.plus.net (195.166.128.183) 36.416 ms 24.056 ms 23.678 ms
3 link-b-central10.pcl-gw02.plus.net (212.159.2.166) 21.551 ms 21.502 ms 21.615 ms
4 xe-10-1-0.pcl-cr02.plus.net (212.159.0.198) 22.771 ms 21.426 ms 21.323 ms
5 ae2.pcl-cr01.plus.net (195.166.129.6) 23.343 ms 42.801 ms 29.321 ms
6 xe-11-1-0.edge3.london2.level3.net (212.187.201.209) 22.918 ms 21.627 ms 21.411 ms
7 vl-3201-ve-128.ebr2.london2.level3.net (4.69.202.177) 28.499 ms 29.378 ms 29.049 ms
8 ae-42-42.ebr1.paris1.level3.net (4.69.159.86) 30.182 ms 27.965 ms 28.300 ms
9 ae-81-81.csw3.paris1.level3.net (4.69.161.86) 28.166 ms 29.282 ms 28.376 ms
10 ae-3-80.edge3.paris1.level3.net (4.69.168.134) 28.098 ms 28.149 ms 27.979 ms
11 telia-level3.paris1.level3.net (4.68.111.194) 29.823 ms 30.321 ms 29.820 ms
12 prs-bb1-link.telia.net (213.155.134.224) 29.774 ms 30.303 ms 29.264 ms
13 adm-bb3-link.telia.net (213.155.137.146) 34.093 ms
adm-bb3-link.telia.net (213.155.136.20) 34.873 ms
adm-bb3-link.telia.net (213.155.137.136) 34.469 ms
14 adm-b5-link.telia.net (80.91.246.101) 37.808 ms 34.830 ms
adm-b5-link.telia.net (80.91.253.171) 34.579 ms
15 facebook-ic-156922-adm-b5.c.telia.net (62.115.11.50) 34.392 ms 34.116 ms 33.961 ms
16 po126.msw01.05.ams2.tfbnw.net (74.119.76.211) 34.873 ms 34.732 ms 34.029 ms
17 edge-star-shv-05-ams2.facebook.com (31.13.64.81) 33.774 ms 34.729 ms 42.193 ms
traceroute: Warning: www.twitter.com has multiple addresses; using 199.16.156.198
traceroute to twitter.com (199.16.156.198), 64 hops max, 72 byte packets
1 10.0.1.1 (10.0.1.1) 3.554 ms 4.084 ms 4.055 ms
2 lo0-central10.pcl-ag02.plus.net (195.166.128.183) 21.856 ms 158.130 ms 23.907 ms
3 link-a-central10.pcl-gw01.plus.net (212.159.2.164) 21.843 ms 162.758 ms 21.966 ms
4 xe-10-1-0.pcl-cr01.plus.net (212.159.0.196) 144.603 ms 21.917 ms 165.502 ms
5 xe-11-1-0.edge3.london2.level3.net (212.187.201.209) 21.562 ms 22.174 ms 144.490 ms
6 vl-3101-ve-127.ebr1.london2.level3.net (4.69.202.169) 22.143 ms 22.816 ms 21.971 ms
7 ae-46-46.ebr1.london15.level3.net (4.69.159.70) 162.688 ms 22.072 ms 22.121 ms
8 ae-43-43.ebr1.london1.level3.net (4.69.167.26) 164.173 ms 31.045 ms 155.507 ms
9 ae-57-112.csw1.london1.level3.net (4.69.153.118) 22.000 ms 22.116 ms 21.797 ms
10 ae-122-3508.edge4.london1.level3.net (4.69.166.13) 141.577 ms 22.207 ms 22.161 ms
11 twitter-inc.edge4.london1.level3.net (212.113.14.238) 163.349 ms 25.499 ms 166.162 ms
12 xe-1-2-1.iad-cr2.twttr.com (199.16.159.125) 96.547 ms 97.280 ms 96.270 ms
13 ae53.atl1-er1.net.twttr.net (199.16.159.75) 113.025 ms 112.994 ms 112.607 ms
14 199.16.156.198 (199.16.156.198) 113.045 ms 112.368 ms 109.324 ms
25-04-2014 9:15 AM
It's a really strange problem because if it was a faulty network device, then you would expect it to affect everything on Port 80 rather than selective sites.
25-04-2014 9:37 AM
I totally agree that it is as mad as the Mad Hatters tea party.
In all my years working in IT I've never seen anything like this
25-04-2014 9:52 AM
I would think replacing the Openreach Modem might be a good idea. Do you have one you could borrow from some friends to test?
Edit: Something else I am wondering - is it possible for Plusnet to do the equivalent of a traffic dump (TCP Dump) their end?
25-04-2014 12:30 PM
ADSL connections typically have a MTU of 1500, but PPPoE normally limits the MTU to 1492.
05-05-2014 11:04 AM
Quote from: ejs I doubt that will help, but in case it does, you could also try setting a MTU of 1492 on your computer.
it would seem that your doubts are indeed sound. Both the suggested values do not fix the issue.
I tried both a wifi connected PC and one one ethernet, changing their respective values has not helped http://support.apple.com/kb/ht2532
05-05-2014 1:14 PM
I've just replied to Ticket: 84535862 advising another step to try. As advised it appears your router is logged in with the wrong realm (@plus.net instead of @plusdsl.net), if you could update this to correctly end in @plusdsl.net and see if this works.
Thanks,
Dan.
23-05-2014 2:01 PM
It would seem that this issue is as simple as logging onto a almost (but not quite) fully functioning domain (plus.net)
Updating the username to be USERNAME@plusdsl.net has resolved the issue. It would seem that the plus.net domain is not correctly configured.
I believe that it should be either retired or made a mirror of plusdsl.net in order to ensure that this does not happen to anyone again
- « Previous
- Next »
