O2's Tu Go service No call volume on incoming or outgoing calls
- O2's Tu Go service No call volume on incoming or o...
Re: O2's Tu Go service No call volume on incoming or outgoing calls
22-04-2014 6:43 PM
nmap -Pn -p 80 --traceroute www.nyc-architecture.com
Here are my results:
Quote Starting Nmap 5.21 ( http://nmap.org ) at 2014-04-22 18:41 BST
Nmap scan report for www.nyc-architecture.com (66.96.132.67)
Host is up (0.091s latency).
rDNS record for 66.96.132.67: 67.132.96.66.static.eigbox.net
PORT STATE SERVICE
80/tcp open http
TRACEROUTE (using port 80/tcp)
HOP RTT ADDRESS
1 1.34 ms router.asus.com (192.168.1.1)
2 36.24 ms lo0-central10.ptn-ag01.plus.net (195.166.128.190)
3 5.60 ms link-b-central10.ptn-gw02.plus.net (212.159.2.130)
4 4.91 ms xe-5-2-0.ptw-cr02.plus.net (212.159.0.106)
5 5.31 ms ae2.ptw-cr01.plus.net (195.166.129.4)
6 5.09 ms ae1.pcl-cr01.plus.net (195.166.129.1)
7 5.42 ms ae-52-52.csw2.London1.Level3.net (4.69.139.120)
8 4.99 ms ae-225-3601.edge3.London1.Level3.net (4.69.166.146)
9 6.71 ms be3043.ccr22.lon01.atlas.cogentco.com (130.117.15.245)
10 11.54 ms ae-61-61.csw1.Paris1.Level3.net (4.69.161.78)
11 91.36 ms be2391.ccr22.bos01.atlas.cogentco.com (154.54.44.237)
12 91.15 ms endurance-international-group.demarc.cogentco.com (38.97.106.34)
13 15.04 ms be2313.mpd22.par01.atlas.cogentco.com (154.54.73.253)
14 14.34 ms be2272.ccr22.lon13.atlas.cogentco.com (130.117.49.121)
15 91.45 ms 67.132.96.66.static.eigbox.net (66.96.132.67)
Nmap scan report for voomka.com (192.163.208.88)
Host is up (0.13s latency).
rDNS record for 192.163.208.88: 192-163-208-88.unifiedlayer.com
PORT STATE SERVICE
80/tcp open http
HOP RTT ADDRESS
1 1.37 ms router.asus.com (192.168.1.1)
2 12.75 ms lo0-central10.ptn-ag01.plus.net (195.166.128.190)
3 5.44 ms link-a-central10.ptn-gw01.plus.net (212.159.2.128)
4 5.05 ms xe-5-2-0.ptw-cr01.plus.net (212.159.0.104)
5 ...
6 73.76 ms 100ge1-1.core1.nyc4.he.net (72.52.92.166)
7 87.66 ms 100ge7-2.core1.chi1.he.net (184.105.223.161)
8 119.63 ms 10ge3-2.core1.den1.he.net (184.105.213.86)
9 133.50 ms 10ge4-2.core1.slc1.he.net (184.105.222.154)
10 174.64 ms ace-data-centers-inc.10gigabitethernet1-4.core1.slc1.he.net (66.160.133.118)
11 131.29 ms ve15.ar04.prov.acedc.net (199.58.196.65)
12 131.99 ms prv-211-1-1-1.unifiedlayer.com (69.27.175.145)
13 131.60 ms 192-163-208-88.unifiedlayer.com (192.163.208.88)
Nmap scan report for offgridquest.com (162.144.62.181)
rDNS record for 162.144.62.181: server.campinglifequest.com
PORT STATE SERVICE
80/tcp open http
HOP RTT ADDRESS
1 1.33 ms router.asus.com (192.168.1.1)
2 25.23 ms lo0-central10.ptn-ag01.plus.net (195.166.128.190)
3 5.35 ms link-b-central10.ptn-gw02.plus.net (212.159.2.130)
4 6.73 ms xe-5-2-0.ptw-cr02.plus.net (212.159.0.106)
5 5.10 ms 10gigabitethernet5-1.core1.lon1.he.net (5.57.80.128)
6 5.07 ms 10ge3-1.core1.lon2.he.net (72.52.92.222)
7 70.60 ms 100ge1-1.core1.nyc4.he.net (72.52.92.166)
8 88.14 ms 100ge7-2.core1.chi1.he.net (184.105.223.161)
9 116.89 ms 10ge3-2.core1.den1.he.net (184.105.213.86)
10 129.33 ms 10ge4-2.core1.slc1.he.net (184.105.222.154)
11 140.25 ms ace-data-centers-inc.10gigabitethernet1-4.core1.slc1.he.net (66.160.133.118)
12 140.14 ms ve15.ar04.prov.acedc.net (199.58.196.65)
13 132.31 ms prv-211-1-1-2.unifiedlayer.com (69.27.175.147)
14 132.48 ms server.campinglifequest.com (162.144.62.181)
22-04-2014 6:45 PM
Quote Starting Nmap 6.46 ( http://nmap.org ) at 2014-04-22 18:44 BST
Host is up.
PORT STATE SERVICE
80/tcp filtered http
TRACEROUTE (using proto 1/icmp)
HOP RTT ADDRESS
1 4.63 ms 10.0.1.1
2 23.45 ms lo0-central10.pcl-ag02.plus.net (195.166.128.183)
3 22.98 ms link-b-central10.pcl-gw02.plus.net (212.159.2.166)
4 23.48 ms xe-10-1-0.pcl-cr02.plus.net (212.159.0.198)
5 23.50 ms ae1.ptw-cr02.plus.net (195.166.129.2)
6 23.53 ms ae2.ptw-cr01.plus.net (195.166.129.4)
7 22.95 ms te-4-2.car5.London1.Level3.net (217.163.45.249)
8 23.56 ms ae-52-52.csw2.London1.Level3.net (4.69.139.120)
9 22.95 ms ae-228-3604.edge3.London1.Level3.net (4.69.166.158)
10 23.68 ms be3043.ccr22.lon01.atlas.cogentco.com (130.117.15.245)
11 23.51 ms be2315.ccr22.lon13.atlas.cogentco.com (154.54.73.109)
12 109.16 ms be2389.ccr22.bos01.atlas.cogentco.com (154.54.44.181)
13 ... 30
Nmap done: 1 IP address (1 host up) scanned in 8.85 seconds
22-04-2014 6:49 PM
Quote Starting Nmap 6.46 ( http://nmap.org ) at 2014-04-22 18:48 BST
Host is up.
PORT STATE SERVICE
HOP RTT ADDRESS
1 6.97 ms 10.0.1.1
2 30.40 ms lo0-central10.pcl-ag02.plus.net (195.166.128.183)
3 23.68 ms link-a-central10.pcl-gw01.plus.net (212.159.2.164)
4 24.07 ms xe-10-1-0.pcl-cr01.plus.net (212.159.0.196)
5 24.08 ms ae1.ptw-cr01.plus.net (195.166.129.0)
6 23.69 ms ae2.ptw-cr02.plus.net (195.166.129.5)
7 33.79 ms 10gigabitethernet5-1.core1.lon1.he.net (5.57.80.128)
8 35.18 ms 10ge3-1.core1.lon2.he.net (72.52.92.222)
9 96.58 ms 100ge1-1.core1.nyc4.he.net (72.52.92.166)
10 106.55 ms 100ge7-2.core1.chi1.he.net (184.105.223.161)
11 135.98 ms 10ge3-2.core1.den1.he.net (184.105.213.86)
12 153.72 ms 10ge4-2.core1.slc1.he.net (184.105.222.154)
13 ... 30
Host is up.
PORT STATE SERVICE
HOP RTT ADDRESS
1 6.01 ms 10.0.1.1
2 28.04 ms lo0-central10.pcl-ag02.plus.net (195.166.128.183)
3 23.59 ms link-b-central10.pcl-gw02.plus.net (212.159.2.166)
4 23.57 ms xe-10-1-0.pcl-cr02.plus.net (212.159.0.198)
5 38.09 ms ae2.pcl-cr01.plus.net (195.166.129.6)
6 25.14 ms ae1.ptw-cr01.plus.net (195.166.129.0)
7 ...
8 89.36 ms 100ge1-1.core1.nyc4.he.net (72.52.92.166)
9 116.42 ms 100ge7-2.core1.chi1.he.net (184.105.223.161)
10 136.53 ms 10ge3-2.core1.den1.he.net (184.105.213.86)
11 176.23 ms 10ge4-2.core1.slc1.he.net (184.105.222.154)
12 ... 30
22-04-2014 6:55 PM
Something is blocking your requests as it should be coming back 'open' rather than 'filtered' on TCP Port 80.
Filtered means a firewall/service/network device is blocking access to that port, meaning nmap cannot tell if it is open or closed. For a website, TCP 80 should be open because that is what you use to connect to it.
Next step will be to figure out where it's being blocked.
- Edit: Just to make sure of something, but if you go here http://www.whatismyip.com/ does it say you have a Plusnet IP?
23-04-2014 10:49 AM
24-04-2014 8:17 AM
In using her new connection for the afternoon this has really highlighted other parts of my own issue. Often it's difficult to see outside your own situation until you are in another.
First off, all of the affected services work at my friends place fault free. I also observed that even though her download and upload speeds are a fraction of mine (speed test attached) my laptop was so much more responsive when surfing the web using her connection. There was very little delay in loading pages and this really has highlighted just how much delay there is on my own connection when accessing "good" websites.
So at home my web page loads are slow with elements often failing to load (see attached), I can not use key services over the PlusNet network, I am unable to see the web in its entirety and the worst of it is that it would seem that this has been the way of it since I first joined.
The "offline team" has been also been looking into this for some time, I'm hoping that they get back to me today as promised. This is really starting to get me down.
24-04-2014 8:28 AM
24-04-2014 9:21 AM
Definitely sounds like you have some sort of fault, or dodgy router to me now.
Ex-Broadband Service Manager
24-04-2014 9:29 AM
Could it be the BT fibre router thats at fault?
24-04-2014 9:34 AM
I'm pretty sure that the problems you are having are down to ports 80/8080 etc. being blocked for certain sites - but it's a little weird how it seems to be only certain sites.
Do you have any kind of firewall or filtering device on your network? Do you run a VPN? Did you check to make sure your IP shows up as a Plusnet IP?
24-04-2014 9:41 AM
Yes it's a very odd one indeed, I've no firewall other than locally on the clients and the PlusNet online FW. Again we've tested with both of these in the off position and the issue remained.
I'll look into Wireshark as I've not heard of that.
24-04-2014 9:52 AM
It could be the Openreach modem. Is it a Huawei HG612 by any chance?
24-04-2014 10:33 AM
24-04-2014 10:47 AM
It looks like I don't have the affected router anyway
24-04-2014 11:08 AM
Both of the BT modems are, however, routers running in 'bridge mode' pretending to be a modem.
Regardless of mode, they're likely to run packets through layer 3 / 4 processing of some sort as they implement TR069 and a management interface to BT.
Interesting that it all works fine from a PlusNet DSL connection though...
