O2 TuGo - Traffic prioritisation
- Re: O2 TuGo - Traffic prioritisation
23-05-2014 4:21 PM
Seems like the 02 app is not been correctly identified the traffic prioritisation system
I have spoken to O2 , they say the app uses Ports 5060 and 5061 UDP.
Kind Regards
Mike
23-05-2014 10:05 PM
http://community.plus.net/library/faults/using-wireshark-for-data-capture/#queues
I believe O2 tugo can be installed on a PC.
27-05-2014 9:31 AM
Is it possible for one of the DC members can pass the query on to the relevant team?
Kind Regards
Mike
27-05-2014 9:34 AM
I've passed this on to Dave to take a look at this for you.
27-05-2014 9:40 AM
27-05-2014 10:06 AM
We could ideally do with 2 captures if possible. If you are able to do this, that would be great. Can you also ensure that you start running the WS Capture before starting the application?
27-05-2014 10:26 AM
Kind Regards
Mike
27-05-2014 10:30 AM
That's perfect, thanks very much.
27-05-2014 11:15 AM
http://www.o2.co.uk/apps/tu-go#download
Having spoken to O2 tech support, to see if there was possible work around to get it running on 8/8.1, short answer is no.
If there any other PN customers who are having problems with the TuGo app , please post
Kind Regards
Mike
27-05-2014 11:18 AM
If anyone can do as above and send me the captures that'd be really helpful!
27-05-2014 11:22 AM
Kind Regards
Mike
27-05-2014 11:44 AM
27-05-2014 12:42 PM
Will do WS Capture later
Kind Regards
Mike
28-05-2014 8:59 AM
Kind Regards
Mike
28-05-2014 9:04 AM
Thanks for that, I've replied to your ticket and I've passed on those captures to Dave.
