O2 TuGo - Traffic prioritisation
ITWorks
Fixes: 9
I have noticed , if i am downloading a file ( for example download.com) , then make a call on the 02 TuGo app (VoIP) from my mobile, the  call quality is terrible and the other person sounds like a robot, and speaking very slowly.  As soon as the download is paused/complete , the app works fine
Seems like the 02 app is not been correctly identified the traffic prioritisation system
I  have spoken to O2 , they say the app uses Ports  5060 and 5061 UDP.
Kind Regards
Mike
31 REPLIES 31
npr
Fixes: 9
Re: O2 TuGo - Traffic prioritisation
Since you've got no answer for PN, you could test for your self.
http://community.plus.net/library/faults/using-wireshark-for-data-capture/#queues
I believe O2 tugo can be installed on a PC.
ITWorks
Fixes: 9
I am unable to at the moment, as i can not open a new ticket , as i have 4 open tickets (maximum allowed on the PN system)
Is it possible for one of the DC members can pass the query on to the relevant team?
Kind Regards
Mike
Pettitto
Fixes: 5
Hi Mike,
I've passed this on to Dave to take a look at this for you.
ITWorks
Fixes: 9
Thanks Chris, much appreciated
Pettitto
Fixes: 5
Would you be able to get us the Wireshark Capture you mentioned so we can provide this to our Products Team?
We could ideally do with 2 captures if possible. If you are able to do this, that would be great. Can you also ensure that you start running the WS Capture before starting the application?
ITWorks
Fixes: 9
Yes , will post back when done, will upload to MailFileShare ( due to having maximum open tickets on my account), and PM you the link, hope that's okay?
Kind Regards
Mike
Pettitto
Fixes: 5
Hi Mike,
That's perfect, thanks very much.
ITWorks
Fixes: 9
Hi Chris, unfortunately  i can not do the WS Capture, as the PC download is for Windows 7 only Sad , and my systems are 8/8.1
http://www.o2.co.uk/apps/tu-go#download
Having spoken to O2 tech support, to see if there was possible work around to get it running on 8/8.1, short answer is no.
If there any other PN customers who are having problems with the TuGo app , please post Smiley
Kind Regards
Mike
Pettitto
Fixes: 5
Ah, shame Sad
If anyone can do as above and send me the captures that'd be really helpful!
ITWorks
Fixes: 9
I will try and get hold of a Win 7 laptop next week, as Chris says if anyone can help in the meantime , that would be very much appreciated  Smiley
Kind Regards
Mike
AndyH
Download the file, right click on it and select Properties. You can run the program in Windows 7 compatibility mode.
ITWorks
Fixes: 9
I asked the O2 tech person if it would run in compatibility mode, he came back with no, just given it a try and seems to be working, thanks .
Will do WS Capture later Smiley
Kind Regards
Mike
ITWorks
Fixes: 9
Hi Chris , i have a ticket open on my account , with the captures required , #86272190 ( got one of my other tickets closed, as its been dealt with since yesterday Smiley ) ,
Kind Regards
Mike
Pettitto
Fixes: 5
Hi Mike,
Thanks for that, I've replied to your ticket and I've passed on those captures to Dave.
