Now more frequent disconnects after "boost Engineer"
- Now more frequent disconnects after "boost Enginee...
24-05-2015 10:57 AM
He couldn't identify a problem, but installed a new wall socket with direct connection from my router which removes the need for a filter.
However, since then I have still had many disconnects, which seem to be increasing in frequency. It's affecting work and leisure, with streamed TV often being interrupted.
To summarise, I've gone down all the routes you suggested to get this fixed, and I'm wondering where I go from here.
Re: Now more frequent disconnects after "boost Engineer"
24-05-2015 7:29 PM
Are the disconnections associated with using the phone?
25-05-2015 12:49 PM
29-05-2015 12:12 PM
@Spacie,
Any improvement with the new router? Can you please answer my previous questions?
@CRT,
RADIUS plot improved any?
Kevin
29-05-2015 12:29 PM
<img src="http://community.plus.net/visualradius/generated/image14328989207255.png"/>
I've not got the history of the case, assuming everything internal has been done, I'd suggest another engineer or possibly an SNR increase/interleaving.
